HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
hartiberlin
I just found a higher resolution video of this small toy generator that drives 2 Fans in 720p resolution.
https://www.youtube.com/watch?v=WGjlaAllUIU
there you can much better see these H bar hydrogen foam rectifiers...
nix85
No need, i already shared more than enough about these things (vril) recently and over the years. These things have been discussed here since early days, but nowdays no one seems even interested. I won't post anymore on water engine threads, i am not really interested in water engines anyway, in fact, i think they are primitive and should not be used. I just wanted to expand the awareness of how big the niche is. Continute to discuss Zografos only.
hartiberlin
hartiberlin
Here is again the small case 2 fans generator better seen in this video:
https://www.youtube.com/watch?v=Z_DmWEQf7_0
at around Minute 59 in the video.
It seems his H-bar bridge has in the center just a solder point, or maybe a gunn diode or PIN transistorto rectify the RF from the metallic hydrogen is sitting below the PCB and so is not seen ?
hartiberlin
these 2 metallic electrodes which are puts in there could be Silver and Zink metal, which gives off a difference voltage of about 1 Volts,
which is probably enough to start these 2 oscillators sitting on the sides of the case to generate the hydrogen electrolysis...
How the question is only , how does he rectify this hydrogen foam into DC in this small unit ??
