HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
Sergh
 ;D  ;D  ;D I found an unknown patent for a motor on the water!  ;D  ;D  ;D
Kapanadze internal combustion engine on water.
The link to official source:
http://www.sakpatenti.gov.ge/en/search_engine/view/8181/1/
Sergh
Patent translate with Google, from Georgian to English, written weird..:
QuoteReduction of economic expenditures, increase of the coefficient of activity and work reliability.
The essence
The engine consists of a cylinder 14, a piston 1, a water tank 4, a knife lamp 8, which is placed on top of the combustion 13 and in the lower part of the cylinder, there are 7 encapsulated condensers 2 connected to a high frequency generator 10.
Description of the patent
The invention belongs to the internal combustion engines, and can be used in various internal combustion engines, namely, in mobile engines mechanisms, for example, in the production of a car.
   It is known for many internal combustion engines, in which the liquid and gas power carriers are used as different agents.
   It is also known that the internal combustion engine on the gas pump, where hydrogen gas is in high pressure separately in a special airbag and from there it is connected to the carburetor of the intracellular engine.
    The technical outcome of the invention is safety, safety of the internal engine and reduction of the energy cost.
    Technical results are achieved by the fact that the internal engine is performed on the top of the cylinder, and in the cylinder combustion chamber, plate or cylindrical capacitor is placed in the water placed under the candle.
    The hydrogen inner engine is represented by 1 figure and contains: Cylinder 14, piston 1, condenser 2, water retractor 3, water tank 4, sparkle lamp 5, residual gas output 6, candle 5 to water volume 7, 8 knees, knee lights 9 and high frequency generator 10.
    Hydrogen inner engine works as follows: High Frequency Generator 10 delivers approximately 50 MHz frequency density 2 plates of condenser, which are used for dilution as distilled water.
High frequency plates on the condenser leads to the impulsive breakdown of the water
dielectric, causing the breakdown of water impulsively. Hydrogen 11 is excreted, after which the blast is carried out by the candle 5 at the moment when the piston is in the lower margin level. As a result of the explosion hydrogen will turn into a high pressure water steam 12 and the piston 1 is moved to the top position, the excess water vapor is removed from the bulb in the muffin (not shown on the moped figure). The number of hydrogen from water is regulated by high frequency regulator 10.
Thus, in the cylinder combustion chamber 13, under the candle (regulation of water level in the cylinder is not shown due to its simplicity and the overloading of the drawing), plate or cylindrical capacitor in the water in the water, eliminates the availability of airbags and pipes, hydrogen formation and explosion occurs directly in the combustion chamber.
                         The invention
      The internal combustion engine containing a cylinder, a combustion chamber, a candle, a piston, a knee lamp, a high frequency generator, a water tank, is different from that of a knife lined above the combustion chamber and in the lower part of the cylinder, placed in the bottom of a candle, placed in a plate or cylindrical capacitor , Which is associated with high frequency generator.
"approximately 50 MHz frequency density 2 plates of condenser, which are used for dilution as distilled water. High frequency plates on the condenser leads to the impulsive breakdown of the water dielectric, causing the breakdown of water impulsively. Hydrogen 11 is excreted"
I understand that the author describes some real process. But I can't imagine it now. If you just put 50 MHz into the water - I'm sure that nothing will happen.
Electrolysis by alternating current of high frequency? In distilled water? Explosive hydrogen release?
Impossible!
Something other. Not electrolysis. I do not know how yet.
May need more power 50 MHz? Or a special design and material plates "capacitor"?
kolbacict
QuoteI understand that the author describes some real process. But I can't imagine it now.
I don't understand it as well.
There is a man who understands. But silent. Wesley
They drank alcohol with him. In Georgia. :)
In general, everyone is silent ... :'(
Sergh
 ;D ah-ah, drank alcohol... ;D in Georgia ... You were in Georgia? For people from the USA:  Georgia, the homeland of Kapanadze, is the exUSSR country in the Caucasus. "Drank alcohol" -  drink homemade grape wine in Georgia the same as drinking tea or coffee. This means nothing. Do not look at Wesley as an enemy who hides a secret. Do yourself what you can.
What you can:
In this patent that I found, there is a link to the patent:
RU2243390 Stashevsky I.I. ( RU2243390 Сташевский И.И )
I read it. Look in the internet about the "Motor Stashevsky" etc...
