HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
Sergh
Strange videos. Maybe the magnet is oxidized. But why does it oxidize much faster when something is fed through the wires?
I cannot imagine that no high-frequency current is supplied.
http://www.youtube.com/watch?v=0yf9p96xu_w
http://www.youtube.com/watch?v=SgQwr_nUG08
Only if glass is conductive...?
https://translate.google.com/translate?sl=ru&tl=en&u=http%3A%2F%2Fauto-minsk.maxbb.ru%2Ftopic455.html
http://auto-minsk.maxbb.ru/topic455.html
Probably on first video with magnet used conductive glass, as he used for the electrolyzer. Otherwise, at an alternating current, the bubbles did not twist around the magnet.
But why then does the glass not work as a cathode or anode? In this case, on the glass itself should stand out bubbles. Unclear.
kolbacict
very strange.  :)  We will try it today.  ;)  Just put the wire from the Kacher in a small container with water, nothing happened.
the container was also placed at the top of the coil.
And if it is not a magnet for a piece of radioactive material.  :o What intensity should be radiation so that gas is released?
kolbacict
There is no gas there. Not with a magnet, not without a magnet. They all lie. :'(
kolbacict
Tried yesterday.  :) Hot wire Kacher was lowered into a cup with water on the ground. Glass and plastic. The frequency was about 1 MHz. Then the magnet was wrapped with a wire. There was no bubble. The power was because in half a minute the bottom of the plastic cup had burnt out and the water flowed out.
