Permanent Magnet Motor- gobs and gobs of free energy!!!...
Started by MagnaProp, March 02, 2016, 11:50:59 PM
stoyan_
@Magna
"What position does your design try to get to and how does that position constantly change?"
same as with Lorentz equivalent design.
stoyan_
" In your Lorentz diagram, when the magnetic force arrows move in the same direction you get repulsion. When the arrows crash into each other, you get attraction."
maybe it is exactly the opposite->
when the arrows are opposite, i get repulsion, when same direction i get attraction.
MagnaProp
Quote from: stoyan_ on March 09, 2016, 04:17:51 PM
I'm referring to the small field lines in your diagram. You mention compression and the lines try to become short again. I can agree with that but why are the lines not compressed equally on both sides of the central point of magnetic radiation? My answer is when the lines crash into each other, attraction occurs so the lines are shorter. When the lines move in the same direction, repulsion occurs so the lines get longer.
stoyan_
so the configuration of magnetic field lines from shielded magnet and the ring magnet  Doesn't represent the same picture as attached by you ?
