New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
Zeitmaschine
If surplus energy arrives looping back should be a minor problem. 8)
One more comparison:
Left hand side, the resonant LC circuit works in 3-phase mode, right hand side the resonant LC circuit works in 1-phase mode. Left hand side the L is a choke, right hand side the L is a transformer (don't know to which extent that matters). The transformer in the background on the left hand side should have its smaller equivalent in the tin can on the right hand side.
cheappower2012
Hoppy
QuoteIndeed! The fundamental problem: How to loop-back, so
the battery and inverter can be removed as we see in Kapanadze's green box video.
Did it ever ocurr to you that the devices that do not need the inverter,battery and transformer with bridge rectifier bridge
to operate use 2 devices in one,one supplies  the energy for the device to be looped for both devices.The other supplies energy to the load,this is how the aquarium 2 device works without an inverter.The 2004 device and the green box device ,are one device, so require an inverter,a big battery and a transformer with a bridge rectifier to achieve a loop condition.
Tariel is a lot smarter and ingenious than you might believe.
a.king21
Kapanadze shows you how to loop back in his patents.  duhhh.
cheappower2012
Aking21
I have a lot of respect for you having the guts to try
to get Kapanadzes device to the general public,you also caught
Tariel at hes weakest moment,and he dropped hes guard.
You have been lied to from the word go,the patents are nonsense
they show nothing,lead to nothing.It is not a Tesla invention nor has it anything to do with Tesla,Tariel says it does, to make people
focus on Tesla not Tariel.There all kinds of ways of looping,you can use a hardware model to simulate a device then loop it,it doesn't matter as
long as you supply the energy, in a real device the device would supply
the energy,its not magic,some things have to follow known rules,some
must be outside known rules for a real world overunity device to be real.
Hoppy
Quote from: cheappower2012 on April 22, 2016, 06:57:28 PM
Hoppy
Cheappower,
The point I made about the need to remove the battery and inverter in the case of the green box device was that if the device works outside of conventional principles, then the loop-back is needed for the device to run itself without help from any power supply provided by the user. A system working oiutside of conventional principles is clearly not what Tariel is running. I suggest that although I think I understand what you are saying, for the benefit of others, a block schematic from you would be better understood.
