New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
leo48
Kapanadze its equipment uses recycled material and therefore it is greatest that's okay
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Zeitmaschine
Schematic below just for illustration. :)
That resistor could be any load like an incandescent light bulb or a heater. In any case it would double the frequency supplied to the coil which is connected in series with the capacitor. The upper transformer is step-down 50Hz (mains in), the lower transformer is step-up 100Hz. Interesting configuration. One 3-phase transformer running at two frequencies at a time. But I think there is still something missing.
leo48
I managed to recover an enlarged photo of the transformer
Leo48
cheappower2012
Hoppy
The way I view both the tpu and tariels device is a certain amount of it runs under conventional
electronic principles,the part generating the overunity does not,however a conventional electronic
method is used in a strange way to create the overunity.It takes a given amount of energy
in my opinion to create the condition that produces the overunity and this has to
be supplied or the condition stops,therefore the overunity stops.This is why the device must be
looped to operate.If you look at the 2004 video they take a reading of the current drawn by the device
to produce the output,that must be supplied to maintain the 4kw output.It looks to be around 80 to 100 watts.
The one device picture shows the method used in the 2004 and green box videos,the second picture is like the aquarium 2
video and others using a 9 volt battery to start the device.Of course there is more circuitry
in the 2 devices picture since the device one, has to generate an ac 50 hz signal and generate 220 vac
from the 12 volts and create an independent 50 hz 220 vac when powered by the second devices 50 hz,220 vac output.
The new video from Tariel is outrageous,I agree with leo48 the black box is the real device,the
motor connected to the what ever that is,is to distract the investor.Hes using the same fake out that he used with the magic wheel.The transformer used is connected to the 3 phase motor not a functional
part of the black box in my opinion.
Hoppy
Cheappower,
Thanks for the schematics to explain the two modes of operation. I had heard that Tariel messed about with generators and here is the proof. That long length roll of thick black cable is telling in my opinion. If he was running the green box device from the generator, via that cable, we have been concentrating our thoughts on the wrong end of the device!
