New April 2016 Video from Kapanadze shows again KWatts of Free Energy
Started by hartiberlin, April 01, 2016, 06:06:31 PM
Zeitmaschine
That's quite a stretch. How did Kapanadze make sure no observer will demand a runtime that exceeds the capacity of the battery? We should think about that.
Meanwhile a transformer theory of mine: The primary coil of a step-down transformer is supplied by 220V 1A, the secondary coil generates 22V 10A (for simplicity sake). So what has to happen that the secondary coil generates 220V 10A? We need a stronger magnetic field, I guess. The normal way to strengthen the magnetic fields in the transformers core would be to rise the voltage supplied by the primary coil (saturation disregarded). But doing so will also rise the current going through the primary coil (thus the stronger magnetic field). But what if there were a different way to get a stronger magnetic field in the core of the transformer? A static electric field can generate a magnetic field when set in motion. Now if we set that static field in motion not mechanically but by means of another magnetic field within a transformer, where one coil generates a static field and one coil a magnetic field. Will those magnetic fields add up? Or even multiply?
Hoppy
Quote from: Zeitmaschine on April 28, 2016, 10:30:19 AM
Not at all. As I understand things, Kapanadze runs the show. I imagine that observers don't demand anything when on his turf! They may ask nicely but I'm sure that he would not have allowed anything that might risk spilling the beans. You may recall the security guys he had near the house during the transparent box demo.
cheappower2012
Both points of view are good,however the concept that a investor
is a complete fool and would not demand a much longer run is not totally creditable.
People with money are very tight with there money,small fish maybe greedy enough.
This silly contraption in my opinion is a return to the mechanical
wheel type of devices that he did a long time ago.The question is why,did the investors reject
the solid state devices or did Tariel cheat so many people that
nobody lines up to invest in any devices so he has to come up with a new
trick,overunity oil motor turning generator.In my opinion the real power source is the black box
The black box powers the motor which turns the oil pump,the excess is used to power lights,heater.
If the motor is 3hp the devices output would be enough to power the motor and load.
If the generator provided the current to a load ,at start up it would slowly
light the lamps up,notice no load  on, as the device powers up.If this was an inverter/battery setup
it should power up real quick.In any case there is no real information of use in this new device
Tariel looks to be in much better health so he will not screw up.
Hoppy
An induction motor running as a generator needs to be running at speed before being loaded.
It is highly probable that this generator was running the garden devices via the cable we see coiled up. As to whether the generator was running OU remains unknown. However, if I were an investor, I would certainly want to see that red barrel opened up before signing-up but I really cannot see Kapanadze allowing that. No enclosed volume of space capable of hiding an energy source capable of powering a device can be simply dismissed. The black box is too small to hide anything significant. It appears to be just a cable termination box, with maybe some control circuitry. There is a cable access into the red barrel in the back of the box.
Zeitmaschine
Quote from: Hoppy on April 29, 2016, 04:26:02 AM
The Sadolin tin can is also too small to hide anything significant. Nothing new here.
In video #2 I can here a German voice saying »Machma [Machen wir] uns die Aufnahme, daß man die durchgucken kann.« Second voice: »Ja, ja, ja«. (We should take the record in order to look it over. - Yes, yes, yes.)
Does this mean something? Perhaps not.
