An Experiment with compass needle
Started by vineet_kiran, April 07, 2016, 12:27:56 PM
lumen
Yes, the needle will remain stationary but the rotating disc is doing the work turning the generator.
To see this just flip over the generator.
Put the generator on the disc and the compass needle on top of the generator.
vineet_kiran
Quote from: lumen on April 08, 2016, 08:07:17 AM
If needle remains stationary,  how the generator coil will rotate?   Work is done by external magnetic field  by pulling the needle  to maintain its direction.  This pulling force is not transferred to the disc.
lumen
It will only generate power if you rotate disc.
vineet_kiran
Quote from: lumen on April 08, 2016, 09:17:15 AM
How much energy is required to rotate the disc and keep it rotating?  You have to overcome only the friction between bottom of central shaft and ground which requires negligible energy input.  It does not experience any opposing force from the magnets.
lumen
When you rotate the disc you also rotate the generator. If the other end of the generator is connected to compass needle and does not rotate then turning the disc is turning the generator.
