Interesting free energy experiment.
Started by TommeyLReed, April 26, 2016, 09:53:16 AM
TommeyLReed
Hi Paul,
I have most of the parts like the motor and micro controllers chips I can program, I will need to get another 1000w hub motor that will cost about $200.00 and 45lb weight.
The rest is just labor and small parts.
Tom...
mscoffman
Tommy,
I really like the youtube video. Very simple and straight forward. I doubt that there is
any way to prove operation over the internet but this comes as close as I have seen.
One thing is a little funky is the fact that his power tools have no AC plugs on their
cables!
The German motor painter gold is probably a high efficiency Siemens motor. High
efficiency AC motors are usually painted that gold color. One might be able to get even
higher efficiency by running a 240Vac/220Vac motor on 120Vac. More recent date code
motors are even more efficient then older motors with similar ID's. The most recent
Siemens H.E. AC motors are wound with copper tape rather then wire.
A good source of a balanced flywheel is spare parts is from exercise equipment like an
inplace bicycle. They have 40 pound flywheels. I was planning a similar setup and I wanted
to use two such flywheels. I found that a new bench-mount buffer-wheel 3600RPM grinder
could be used as the bearing pillow block assembly by mounting one flywheel on each side of the
grinders shafts and then ignoring the grinder's motor. Pulleys on each inside shaft would transfer
power. A good source for an efficient 96 VDC generator is a new spare DC Treadmill replacement
motors.  I kind of like the concept of using toothed rubber belts like they use on some motorcycles
rather than a chain drive as it keeps components mechanically synchronized but would not require
oil for lubrication.
Just throwing out some ides that I've looked at.
Cherryman
Build it Tommy ! That would be great !!
In my humble opinion Two things at work here..
Timing:  The rubber belts give "play" in timing and (de)synchronizing  As they are not a fixed dimension, the rubber is able to breath... aka live..aka wave..
Relative motion: The relative rotation of any inertial attractive mass is a matter of dimension
Newton II
I would like to know one thing.
If  O/P is more than I/P in that setup,  why do we  need motor and generator?  One wheel on the left,  another wheel on the right with a huge flywheel  in between connected to both wheels by belt arrangement should make a perpetual device!   because  as I guess energy is created  in that setup by flywheel only!  Standard motor and standard  generator are built conforming to conservation law.
TommeyLReed
Hi Newton,
Dc motor like rpms, so if you run the motor at higher speeds you will use less energy to keep it running.
Hub motors only have a limited speed due to the fact so many pulse can take up lots of energy in a single rotation.
This is another reason why a 4:1 ratio is needed.
The real trick is to have a timing circuit using a micro controller to allow both input&output so when the generator pulls energy it is not while the dc motor is on.
Something like this:
1) motor on---generator off = input watts
2) flywheel increase speed  =no load
3) motor off---generator on = charging watts
4) flywheel decrease speed = load
1)motor on---generator off = input watts
And so on.
Tom
