Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
Here2njoy
Here is an interesting video called "the Big Bounce"... Dome perhaps....  https://www.youtube.com/watch?v=xQ08CHvAaQE  You decide....
CANGAS
Quote from: Pirate88179 on May 03, 2016, 04:04:24 PM
A plane does not fly level as much as it maintains a given altitude based upon the engine's power setting.  So, the engine is working against gravity as is the left generated by the wings.  Therefore, it maintains this height above the earth even if flying around the world.  It will continue to do this unless one or more of the parameters change.
A bit of good sense in this desert. Bless you, Pi.
The wing automatically makes lift depending on the the density of the air it is in. And, that lift varies as the airspeed varies. So, if the power setting is left constant, the lift gets bigger if the wing goes into denser air, and, the lift gets smaller if the wing goes into thinner air.
The density of the air is governed by the strength of gravity, whether the source of gravity is the flat plane or the spherical globe. The strength of gravity varies with the altitude above the ground (not exactly, but it makes little difference).
So, the plane as a whole will pretty much automatically hold the same altitude above the ground in "normal" conditions. That is, with no "touches" on the controls needed.
CANGAS 231
gravityblock
Flat Earth: Southern "Hemisphere" Constellations Explained
For each 360 degrees the sun-moon system rotates (one 24 hour day/night) the stars rotate 359 degrees. Over a year this causes the constellations all to have their turn in the day and night part of the sky.  One degree difference per day adds up to one full revolution over a year, this model having 360 day years (12 x 30 day lunar month) just as the ancients used.  360 degrees in a circle and not 365.25.
Sun-Moon Flat Earth Astrolabe Android App
Below is a description of the app and a snapshot:
"This is a version of my Yin Yang Radial Oscillator model which lets you choose a date and time by tapping the screen, and it will show you the sun and moon positions relative to stars and Earth. The yin yang shows areas of night and day. So you can check where and when the sun will rise and set, and see which constellations are visible and where. The red dot shows the centre point of the moon and sun. It also shows world cities with populations >1m and which is nearest to sun and moon. You can toggle all the plates (Earth, stars, cities) on and off as well as whether the display is static or animated by a clock. Now also includes a Moon Compass and daylength calculated from the model time and your latitude if you (optionally) allow GPS permissions. The app does not account for your time zone presently... but you can correct for this manually for now :)"
Gravock
gravityblock
Quote from: Here2njoy on May 04, 2016, 11:55:50 AM
The youtube account for the link has been terminated.  Makes you wonder if the ballers are following the reference links.  I know they wish to remain willfully ignorant, so this doesn't surprise me.
Gravock
gravityblock
