Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
Quote from: gravityblock on May 07, 2016, 11:56:43 PM
The highlighted portion in number 2 above is based on a false premise, and the earth being a flat round disc will also have a radius in regards to the highlighted portion in number 4 above.  In other-words, the highlighted text proves nothing.
Gravock
Wrong again! Sketch the problem given in the passage, from your "flat earth" perspective and show this "radius in regards to the highlighted portion in number 4 above."  You're just full of utter nonsense. Every post you make increases your hilarity and reduces any credibility you may ever have had. Keep it up!
Quote from: seychelles on May 08, 2016, 12:05:10 AM
Now i know why ALIENS would not communicate with us because WE ARE LIKE FUCKING COCKROACHES.. Do i get this right are we in this day and age discussing if the earth is a ball or a flat disc..PLEASE ...
Heh... it's not a discussion at all. It's a _windup_. Look at all the false claims "gravityblock" has made trying to support his nonsensical belief. I don't even think that HE believes it any more, he's just copy-pasting from the internet postings of people too stupid to even do their own research and experimentation.
tinman
Gravock
It is odd that from my geological location,i can watch the stars make an almost straight line trace over the period of night. One would think if i lived on a flat earth,the stars would at least show a trace of 1/2 a full circle during 12 hours of night.
Brad
gravityblock
Quote from: TinselKoala on May 08, 2016, 07:02:36 AM
FALSE again! You are really showing your ignorance and gullibility here. Clearly you have no idea how a real rainbow is produced in nature, nor how to make one yourself.
You have been refuted at every turn. Falsehoods like the above, mistaken interpretations, and simple ignorance of astronomy, aviation, geometry etc. are all you have. And it's hilarious to see you displaying your ignorance as if you are actually _proud_ of it !!!
Keep it up, you are hilarious!
Place a very strong but small source of light in the corner of a big room. Look in the opposite direction from the light source, and use an atomizer to spray a mist of uniform tiny water droplets in the air ahead of you. You will  see a real rainbow, at the characteristic rainbow angle, produced by the same mechanism that happens outside in the sunlight. The "mirrors" are the droplets of water themselves, just as when it happens in the sky.
Here are some more ways to "make a rainbow" indoors (actually, a spectrum projected onto a surface rather than a real rainbow that appears to be in the air), some of which use mirrors and others that do not.
http://www.wikihow.com/Make-a-Rainbow
FFS, learn some physics why don't you?  .... I know why.... you're a windup.
Wrong!
The glass and windows are all slightly reflective.
If the back side of the flask is painted with silver or aluminium paint, more of the light will be reflected and the rainbow should be brighter (see images below and the reference link).  This clearly shows a mirror is essential in making rainbows.  More light being reflected equals a better and brighter rainbow.  No light reflected equals no mirror and no rainbow.
Gravock
Edit:  Added the text above that is in bold.
gravityblock
Quote from: verpies on May 08, 2016, 05:58:55 AM
Don't you think it is possible to distinguish reflection from transmission?
BTW: Do you think the starlight is transmitted or reflected?
Apparently the scientists did not try to distinguish reflection from transmission.  Their antennas were pointing to the "so-called" deep space, so they wrongly assumed the signals were being transmitted instead of being reflected.
The starlight is transmitted.  However, this doesn't mean the transmitted starlight is never reflected between a reflective surface on the earth and the mirror-like firmament dome that is above.  The stars are hanged/embedded into the firmament dome, and this mirror-like dome rotates around the stationary flat earth.  The luminaries are much closer than what has been taught by TPTB.
Gravock
