Is The Earth A Flat Round Disc or Is It a Round Spherical Globe?
Started by gravityblock, April 28, 2016, 12:14:07 PM
Is The Earth A Flat Round Disc, Concave, or Is It a Round Spherical Globe?
The earth is a flat round disc!
The earth is a flat round disc with a dome!
The earth is a round speriical globe!
The earth is concave!
gravityblock
Quote from: antijon on August 05, 2017, 12:30:09 PM
I don't know what you're referring to about the accelerometer.
It is you who brought up the accelerometer and not me.
Gravock
gravityblock
Quote from: antijon on August 02, 2017, 08:36:02 PM
Phones use an accelerometer to run the level app. Because an accelerometer is a weight balanced on springs, it will always point down towards the earth when using the level. I don't understand how this can be taken as evidence for a flat earth. It can't be really. Won't a plumb line always point straight down? Doesn't a dropped object always fall down? It's the same thing. I'm getting confused by the ludicrosity of this experiment.
I don't think I need to tell you that calibrating a level on a level floor will yield the same result on any level floor, but I will. Calibrating a level on a level floor will yield the same result on any level floor, anywhere and everywhere. Now you know, and knowing is half the battle.
Yes, a plumb line will always point straight down, but not the accelermeter as you have falsely asserted.  The accelermeter can point in any direction and show level (you should watch the pre-flight experiments).  If you think otherwise, then you are clearly delusional and don't understand the reason for setting a reference point for level during calibration.  The phone was off during the entire experiment, thus gravity and the accelerometer had no effect on the bubble level app during the experiment.  Ireland being on the other side of the so-called globe could never show level in regards to the same reference point for level obtained during calibration in the u.s.a.  However, Ireland does show level using the same reference point obtained in the u.s.a, thus the earth is flat!
Gravock
antijon
I haven't falsely asserted anything, I know an accelerometer can show a force in any direction. And when an accelerometer is motionless the dominant force acting on it is gravity. That's why the guy didn't put it on his head and do the Macarena when he calibrated it. He wanted it to be calibrated to the level of the floor, as by gravity.
The calibration has nothing to do with location, it only allows you, the user, to set it to show level at what you believe is level. A normal bubble level doesn't need to be calibrated, and you can see what it shows in the video, two level floors. So congrats to the engineers and contractors that built the airports.
Likewise it doesn't matter if the phone was turned off or on, the calibration would remain the same. I don't know where you're coming up with these arguments but you're misunderstanding everything. How do you not see what you're saying as being wrong? I just don't understand.  :-\
gravityblock
Quote from: antijon on August 05, 2017, 03:03:52 PM
The accelerometer can only detect acceleration and not gravity itself.  The accelerometer resting on the floor during calibration isn't undergoing acceleration, thus the accelerometer isn't calibrated on a level floor by gravity as you have once again falsely asserted.  Gravity is nothing more than density and buoyancy.  Anything heavier than air will fall through it and anything lighter than air will rise.
Gravock
gravityblock
antijon,
Let me ask you this question.  Do you think Ireland has the same reference point for level relative to a reference point for level in the u.s.a on a globe model?  I can easily provide an illustration showing how a person standing at one location on a globe doesn't have the same reference point for level, up, down, left, and right relative to a person who is on the other side of the fake globe.
Gravock
