Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
Void
https://en.wikipedia.org/wiki/Gunn_diode
Gunn Diode
"A Gunn diode, also known as a transferred electron device (TED), is a form of diode, a two-terminal passive semiconductor electronic component, with negative resistance, used in high-frequency electronics. It is based on the "Gunn effect" discovered in 1962 by physicist J. B. Gunn. Its largest use is in electronic oscillators to generate microwaves, in applications such as radar speed guns, microwave relay data link transmitters, and automatic door openers.
Its internal construction is unlike other diodes in that it consists only of N-doped semiconductor material, whereas most diodes consist of both P and N-doped regions. It therefore does not conduct in only one direction and cannot rectify alternating current like other diodes, which is why some sources do not use the term diode but prefer TED. "
ramset
Stefan
https://steemit.com/news/@overunitydotcom/how-the-water-to-electricity-petros-zografos-free-energy-fuelcell-system-is-working-from-hellagen-gr
this is an example of an experiment we can "model" here .
we have the open source talent in house [here and elsewhere]
and the builders with a long standing   reputation of sharing here and elsewhere on open source projects... to get this done.......
We have spoken in the past about "how to fund" these Open source projects with 100% transparency  ,..looking forward to those discussions again ,
@Void
nothing but gratitude here....
respectfully
Chet K
Thanks Grandma
hartiberlin
Zografos is probably using Gunn diodes to generate this GigaHz or TerraHz pulse frequency to do the RF electrolysis and then uses Schottky diodes to rectify the RF power to DC.
As I pointed out there are already a few RF to DC power modules on the market in my Steemit.com article that can reach about 60 to 70 % efficiency.
@Chet , yes I am looking into using Steem cryptocurrency to integrate into the forum here or into a new forum , so all the users could benefit from posting.
I would advise already all users to register at steemit.com to setup your Accounts over there already.
Regards, Stefan.
ramset
Thanks Grandma
Sergh
Interesting patent:
https://patents.google.com/patent/CN1072465A/en
QuoteA method and apparatus of preparing hydrogen by microwave electrolysis of steam is disclosed. The apparatus consists of microwave generator and electrolysis tank. Microwave, which comes from the generator passes through the energy entrance of the electrolysis tank into the tank, heats the water in the bottom of tank and vaporizes it. Steam is excited to high energy status, electrolysis is conducted, and hydrogen and oxygen are produced. Under the following conditions: absolute pressure 0.1 MPa-1MPa, temp. 100-180 deg.C. microwave power density 0.1W/cm3-1.2W/cm3, microwave frequency 800-22200 megacycles per second, field intensity of direct current 200-800V/m. This invention has following advantages: high electrolysis efficiency, energy saving, no corrosion to the apparatus and safe production etc..
min. 800 MHz - max 22,2 GHz, absolute pressure 0.1 MPa-1MPa, temp. 100-180 deg.C.(steam) microwave power density 0.1W/cm3-1.2W/cm3, (not too high)
QuoteThe dielectric loss coefficient of water (εtgδ) decreases with increasing temperature, but the water vapor still absorb microwave energy.  According to quantum mechanics, electrons of water molecules, atomic force by high frequency electromagnetic field (microwaves), and the collision between the molecules are excited to a higher energy level, and then applying a DC electric field, it is easy to split water molecules.  Set DC field strength Ed, the microwave electric field intensity Ea of the electric field intensity in the total cell is: E = Ed + Ea E <critical breakdown field strength of the medium.
To split water molecules, the microwave energy is not enough. Therefore, a ordinary direct current is added to the microwave.
It's unclear how high the efficiency is.
CE or not CE.
