Bike runs on water 100 % - No Gasoline - Microwave Pulse Generator Water Split
Started by hartiberlin, May 04, 2016, 02:29:43 AM
Here at Minute 56:37 and following you still can see the small toy box much better:
https://youtu.be/Z_DmWEQf7_0?t=56m37s
From. Minute 59:00 the cameraman shows it quite well..
Could be, that the Voltage for the 2 PCB Ghz circuit boards comes from a  galvanic reaction
from the saltwater and the 2 dissimular metals, cause he has in the compartments 2 different Metals,
which he has connected with his  Brassplate connectors.
the 2 dissimular metals probably power the two Ghz pulse generators PCBs and then the gas is converted on the upper  2 small special  Fuelcells,
which he puts in at the top......These special  Fuelcells then produce the current for the Fan-Motors from the produced Hydrogen and Oxygen...
Seems to be a very efficient electrolysis via these 2 pulse generator PCBs ...
Regards, Stefan.
In the same video
https://youtu.be/Z_DmWEQf7_0?t=2h3m41s
at 2:03:41 you can see again his new reactor. that also works a special "cold ion MHD fuelcell"
with 11.72 volts and 19.6 amps Output. ( Watch the digital Wattmeter)  So the output power is actually
230 Watt and then goes to the inverter, which operates 6 pieces 40 watt bulbs .
After that an electrical drillmachine is then connected to the inverter , which draws 205 Watt
and he drills a hole with it into a piece of wood , so there is already torque power behind it ...!
If he disconnects the drill, it can be seen that the inverter and the electrolysis draw only 15 watts at idle mode ...
at Minute 2:05:52
So you can generate with an input power of about 15 watts about 230 watts of output power ,
so that's a COP of about 15 !!!
Here in the video here:
https://www.youtube.com/watch?v=h_Ps1R03WqM#t=7059.430042
at Minute 1:38:40
He then disassembles all his Waterelectrolyse reactor ...
But it's not a PEM Fuelzelle what I had thought first, but some kind of
"cold ion microwave MHD converter" or so ...
The only question is how he then can still produce about 230 watts of electrical power with this arrangement ...??
So Zografos seems not only to have invented an extremely efficient electrolysis at high Ghz frequencies,
but also a substitute for a PEM Fuelcell that otherwise are always very expensive ...
I just looked it up for a 250 watt PEM Fuelcell you still pay a premium prize of about 500 US$ or more ...
He has somehow used such microwave waveguides, these ones for radar technology or microwave technology
... Hmm ... maybe he used then somehow a MHD power plant effect?
Look here:
http://mhd.pickel.cc/
Maybe he burns the hydrogen (and oxygen ??) gas and then leads these  ions into these steel containers of strong neodymium magnets,
where the ions are separated via the magnets onto pickup electrodes and
then this voltage of about 12 volts and about 20 amps are produced ...
This is really a great job, so it makes these expensive PEM fuel cells obsolete....
Really totally awesome this guy ...! ;)
Now it also gets clear why he also has these many copper tube coils around there...
serving probably to cool down the water vapor in the combustion of the hydrogen in this integrated MHD type generator
and put the condensed water again into the unit ....
So the copper coils are probably  be getting quite hot, so you can use the thing then also in
Winter for heating your home...
Really awesome!
Regards, Stefan.
