Any ACTUAL OU devices on this whole forum
Started by Permanente, May 17, 2016, 08:10:37 PM
memoryman
"Hi if your interested there is a way but It will need some work. I showed this before . go look at the formula for a a string of capacitors in series you will see that the total is equal to the total divided by the number of caps. (All caps being equal in uf's) including the first cap.the charging cap put a positive charge on it and a earth ground on the last cap. And all the calls will generate equal charges.the first cap you will have to charge but the rest charge them selves. By inductance aka free.the more caps the less you have to charge to get the same results.
Pos-----l I------I I------ll------l l --------l l ------(earth ground)
(Applied.    Free. Free  free   free "
This is pure b.s. That's why you see no product based out there based on this.
VMP100
Quote from: memoryman on August 05, 2016, 09:55:33 AM
Memoryman, is there another easy OU device that you can recommend for a beginner to start with?
Solid state is fine too. Thanks.
VMP
memoryman
VMP, sadly there are no OU devices in existence. If you are interested in pursuing promising new energy sources (NOT OU), cavitation may be a start.
jimbo
Vmp look to string soild state devices    captret effect.  Real free energy with caps Thu inductance .there's more there page three has a diagram of two caps and switching . sorry about the delay. Jim
stevensrd1
The water battery can supply power for low current devices for many years. I run led lights, wall clocks and little motors on single water batteries. You can check out my vids on these and how I made them at https://www.youtube.com/stevensrd1 I have also started a fund raiser to try to improve the water battery more and sell some pre maid devices with a water battery. The fundraiser link is https://fundrazr.com/01KBhc?ref=tw_a77LPd_ab_1HvIRPZY9lI1HvIRPZY9lI   I cant say its really over unity but you can wire many water batteries in series and recharge regular AA batteries with them, and do it many many times for years even all the while using the same water batteries to do it with. Is that over unity, who knows.
