Reviewing Pulse Motor Circuit Ideas and Theory
Started by earthbound0729, May 29, 2016, 10:49:22 AM
Magluvin
The Ozzie motor did the same. He used 2 reed switches to completely disconnect the series windings from the batteries and used 2 diodes to redirect the ends of the windings back to the battery in a charging direction. The simple circuit would show the diodes crisscross to redirect back to the battery.
It was hard to get the reeds to sync 'perfectly'.
Mags
shylo
Can it run without batteries, Just charge caps.
Bounce the charge your putting into the drive coil, back at the generating coil.
Which are the same coils.
The coil see's a magnetic field approaching, it makes a flow that creates a flow opposite (that is if it's loaded), but if you direct it (the opposite)
back at the drive.
artv
tinman
Quote from: Erfinder on February 27, 2017, 10:29:20 AM
This is a great example of why it's a bad idea to share schematics before an idea is perfected.....  If you push this circuit as is, changing only what's necessary for proper triggering at higher supply voltage, you may discover why this is not a good idea.
It dose exactly what it was intended to do.
Brad
tinman
Quote from: shylo on February 27, 2017, 08:40:57 PM
back at the drive.
artv
If it could ,i wouldnt be here  ;D
Brad
