H2 to 2H - what are the options?
Started by dieter, June 04, 2016, 04:11:31 PM
pomodoro
Say what you will.....The truth is that Nobody but  nobody beats the awesome Malgarini  paperweights!
ourbobby
Quote from: pomodoro on June 09, 2016, 08:42:47 AM
Actually, this device has the appearance of a Linear Faraday Generator, albeit in its own configuration.
See an example here https://www.google.com.au/patents/US8629572
Maybe not a total loss, if only the details were more specific!
franco malgarini
ourbobby
Quote from: franco malgarini on June 09, 2016, 10:54:27 AM
Cell with also High Tension
________________________________
http://autocostruire.forumcommunity.net/
Hello Franco,
                    Without being insulting, this last drawing is too simplistic. Without going into too much detai,l for starters, the introduction of HV will complicate your design proposition. You will need a controlled atmosphere of moist, warm humidity. Then you are more likely to create a Townsend discharge electron effect, with a high likelihood of plasma discharge. This  in turn will likely breakdown the Nitrogen into hydrogen components and create mass electron flow. Your hope of creating N, H and O will be severely challenged. The chamber required to mount your HV terminals and magnets will require some serious design considerations. I'll not go any further. Good luck, you are definitely on the right track, but have to choose your direction carefully. Leave out the HV and concentrate on the Lorenze effect using magnets in "series" with your electrolysing nodes.
Good luck
