Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
burnit0017
https://youtu.be/aaF1_AyZe-c
proceeding to fabricate swing5 and pulse motor configuration for a gravity assisted pulse motor, it should take a few weeks before the first test
the pulse motor can be made with a larger diameter
No laws of physics are violated and it should function like a wind turbine when generating electricity, output will always be less then 50% of the total power available at the output shaft.
burnit0017
https://youtu.be/yi86QqqBNig
The electromagnet has limits adding two air cylinders with two moving weights may help. Using the swing 5 configuration just add another moving weight to the stationary weight side.  During rotation as one weight falls it will push the other weight toward the center.
ramset
Sir
What constitutes a "swing 5 configuration"..?  is it posted here already [above ] and I missed this or is it to be a new build completely?
respectfully
Chet K
Thanks Grandma
burnit0017
https://youtu.be/jKIWcJiJs04
Hi, I am combining the above videos to form a gravity assisted pulse motor. Then I will using use the electronics from a wind turbine to generate electricity. This is a first attempt so plans may change. Thanks for showing interest.
