Joule thief that could light the whole house
Started by CG2016, July 04, 2016, 04:50:43 PM
conradelektro
Quote from: CG2016 on July 07, 2016, 10:04:11 AM
For some reason inverters have a problem with leds. The brightness of the leds was measured and is the same as when run on mains power. Plus this circuit is much cheaper and runs cooler than an inverter. Maybe you could build it and see. Can the inverter keep lighting the lamps on a dead battery like this can? ( Down to 2.4 volts). I doubt it.
Power supplied by the 12 v battery was measured at 6 watts , Pretty good I'd  say.
So try it. You'll like it. ;D
Light brightness is not easy to measure. You need a light meter
http://www.ebay.com/itm/cmltzone-Digital-Light-Meter-Lumenmeter-200000-Lux-Illuminance-Tester-LCD-/252442663566?hash=item3ac6c15a8e:g:4VkAAOSweWVXc0l4
and a rigorous measuring protocol (best in a box, always the same distance between light meter and light bulb).
I played endlessly with many Joule Thief type circuits and once I got a lumen-meter and learned how to do the light measurements I saw the light. Eye sight is a poor judge of light brightness.
One should not exhaust a 12 V battery down to 2.4 Volts.
There a 12 V LED-lamps for campers, cars and boats, then you need no converter just connect them to the 12 V battery:
http://www.ebay.com/itm/2x-12V-LED-T10-WHITE-LIGHT-Camper-Bulb-Globe-Garden-Wedge-5SMD-Car-Parker/111914619862?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D37254%26meid%3Df55b1b8ba4a34c19b6739ce38996c192%26pid%3D100005%26rk%3D4%26rkt%3D5%26sd%3D121597979142
But if you like your Joule Thief circuit, it is fine with me.
Greetings, Conrad
CG2016
Proper measurements were made, using the exact same criteria in both cases . It functions as advertised. And you can use the batteries you assumed were dead, to run it.
By the way there's something new called an ultra capacitor and it doesn't care much how low it goes etc. Hardly ever goes bad.
SkyWatcher123
Hi cg2016, thanks for showing video, could you please post circuit drawing and build details, thanks.
peace love light
CG2016
Details of the build are mentioned on youtube video description or comments.
I will be making a new video of the updated unit in about a week or so
Here's  a video from a couple years ago of my first unit. The new one is an improved version of this one.
https://youtu.be/og81-4iDyHU
Cherryman
Great sharing!
You know if there is a 220V version  also?
