Cell phone radiation cooking eggs
Started by Floor, August 28, 2016, 01:20:43 PM
Floor
thanks Farmhand for the info / links.
Quote from the UCSB-edu page
"Cell phones have low-power transmitters in them. Many cell phones have two signal strengths
: 0.6 watts and 3 watts (for comparison, most CB radios transmit at 4 watts). The base station
is also transmitting at low power. Low-power transmitters have two advantages: "
....... date unknown
QRZ.com  (comment)
"I searched the net but couldn't find a conclusive answer. Some say 1 watt others say
250mW. Who knows for sure? "  .......Aug 16 2009
Magluvin
I found the article in the link about the wifi router affecting the seeds more informative and believable than the egg vid.
From what I have read recently is that when the sig bars on your phone are full, say 5 bars, that is when the phone puts out minimal sig strength. But if the signal bars are low, the output can be 100 times the low output. I for one would like to get a sig power meter that reads these freq and do some tests, but for other reasons as in testing for harmful radiations.
As for the eggs, I think he had an induction heater under the table/counter top.  Just the fact that the pan was there should be more of a giveaway. Its a shame that people put out such vids that really go well beyond possible. Like just the possibility that all 9 phones would be possibly in sync to hammer just that portion of the pan doesnt jive, along with the metal grills, considering the freq are in the microwave region of the spectrum, and to just set them up anywhere on those grills....  I dont see it at all.
Mags
Smann
Hi. The radiation is actually not strong enough and it would also require a resonating cavity in order to work. Nevertheless, the EM radiation damages the DNA in our cells, even when the warming effect is not enough to heat up our body.
Farmhand
Yeah Floor, you're right there is nothing conclusive.
Mags, you're right too, I also found that to be very interesting. I have just tried to germinate some tomato seeds actually and only one sprouted, I
wondered why the failure and I'm thinking maybe it is because I tried to germinate them upstairs near the wifi router. I wonder if it affects them
while they are in storage or only during the germination process. Germination r ate was very poor, not like usual, usually nearly all germinate but this time only one from 10. It is cold but I had them on a heat pad.
If the seed integrity is compromised by wifi signals even when in storage then I should shield them or store them further away.
conradelektro
There is a very effective solution. You can protect your eye balls with metallic sun glasses, your brain with a metallic hat and your gonads with metallic pants.
And then you connect the three metallic wearables with earth ground.
You should be save with that outfit near your cell phone, your WIFI router and cell phone towers. :P
But nothing can protect you from these dangerous brain waves https://www.youtube.com/watch?v=S9cp_z3Cg-k emitted by aliens all over the earth.  :-X :'(
Greetings, Conrad
