THE INFINITE ARRAY ENERGY GENERATOR PART II
Started by lancaIV, September 02, 2016, 08:05:19 AM
ramset,Chet,
inside the Trilles espacenet documents you see above the FR-Register link,
which let you enter to the french patent office register and there are  three Trilles publications to find - all without his or patent lawyer address !
The patent office can only give to us his last -1998-(last correspondence) address ,we will not know if he is alive or living in the same homestead !
But technically the working process  in his papers is well exposed and documented !
forest
Many of us have studied the total (ever growing) rexresearch archive ;)
About power density,not an actual concern,of using the nuclear forces from elementar magnetism :
  https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP
To clarify the operation of this embodiment according to the invention, the following dimensioning of the transformer windings is given using Figure 17 as an example, the iron cores being dimensioned in accordance with the manner usual for transformers:
- winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;
- winding 82: 1 winding, 5000 A;
- winding 84: 1000 windings, 5000 A;
- winding 85: 1100 windings, 4500 A, 220 V/50 Hz.
From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84. Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000. In the variant indicated in Figure 18 of this fourth embodiment, a two-phase system has been assumed. In a further variant of this embodiment, the latter can also be constructed according to a three-phase system. In the above described variant, a mains frequency of 50 Hz has also been assumed. These embodiments may, however, also be used for other frequencies. [/size]
5000000 "ampere windings"(~rotations/revolution) = 1000 turns winding coil x 5000 A
990 KW :        1/1000 of this value   0,99 KW as target for the home heating system
                                                           600 Watt for an averagde sized (US and elsewhere) home
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130110&CC=US&NR=2013011125A1&KC=A1
The "Rolling Lumens Heater" consists of an 8″×8″×4″ electrical junction box with six lampholders mounted on the exterior of the box. A 100 watt light bulb is placed in each of the lampholders. A 120 volt ac line supplies voltage to the interior of the junction box where each of the lampholders is connected in parallel to the line. The junction box is installed in the cold air return of a forced air furnace or in an enclosure through which hot water pipes travel in a hot water heating system. When the lamps are illuminated, the air driven by an 8 inch fan through the cold air return, or enclosure, is heated to a temperature of 70 degrees Fahrenheit. The heated air is then pushed through the heating system to the registers and out into the rooms where the temperature remains constant at 70 degrees. The cost of operating this system is approximately $30.00 per month for an average size home. No petroleum or fossil fuels are burned in this process with no resultant environmental pollution and inherent health hazards.
                                            Bringing down the autonomous (foldable ? portable ?) house construction market prices,
                                            included energy system and white/grey/no more black water cycle
                                            250 US$/sqm or 25 US$/sqft
http://www.fabprefab.com/fabfiles/otherfabhome.htm Ramon Kalinowski 15000 US$ FPB
  (exposed in
https://books.google.pt/books?id=Zs8DAAAAMBAJ&pg=PA20&lpg=PA20&dq=popular+mechanics+foldable+portable+building&source=bl&ots=IIDzWC28-P&sig=S7dhC-dM5D350e2NZ_SUEK_IG-I&hl=de&sa=X&ved=0ahUKEwik-5ak2fXOAhUDVhQKHbijDqkQ6AEIIjAA#v=onepage&q=popular%20mechanics%20foldable%20portable%20building&f=false )
and this aluminium A-frame house http://www.powerprofile.co.za 10000 US$/64 sqm as            idea prototype
and the morphing (space and volume gain ) concept https://www.youtube.com/watch?v=f-iFJ3ncIDo
Federation of American Scientists : 32-38 sqm Starter      Family House
                                                        72-78 sqm Expanded Family House
relocateable society movement
ramset
Lanca
I really like your new thread,
thx
Chet K
Thanks Grandma
FatBird
How can we look at some drawings, pictures, or schematics?
Thanks.
