Curiosity on chemical process
Started by franco malgarini, September 17, 2016, 01:28:12 PM
Cherryman
Quote from: sm0ky2 on February 02, 2017, 03:54:13 PM
The video you show is the barell siphon.
A barell is placed sideways with an evacuation valve
At the top side of one end.
A siphon tube is placed 45-degrees to the water source
Height of lift is controlled by a vacuum
Water is placed in the barell to a point above the
Output valve at the bottom, directly below the evacuation
port, on the opposite end of the barell.
The barell is then evacuated until water is pulled up from
The source.
Once water begins flowing into the barell, which is usually
audibly detected, the output valve is opened.
The outgoing water maintains the vacuum pressure
Which draws water from the source into the barell.
The distance between the input and the water level
inside the barell, keeps the vacuum stable.
It works for free
So do i get this straight?
With that system i can pump water UP 24/7 without adding energy  ?
That would be great for my aquaponics!
franco malgarini
sm0ky2
Quote from: Cherryman on February 02, 2017, 04:16:35 PM
This system has been heavily debated over the past several years
On this and other forums.
Thousands of South American farmers seem not to care about the
physics, they just use it to water their fields.
The language they use is very non- technical.
Put this in that, do this , and the water comes out.
franco malgarini
franco malgarini
Circular thermal spectrum, cold sun and star motor
