Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
citfta
ayeaye,
Builder and tester "floor" has spent many many hours working with  the interactions of magnets.  He has included many PDF documents in this and his other thread.  He has also posted many videos of his work.  I only tried to apply what I have learned from his PDFs and videos.  If you want to learn a lot about interactions of magnets please take the time to read both of floor's threads and watch his videos and read his PDFs.
Respectfully,
Carroll
#333 : I think that this "NO! " is classical Physics view related,
Quantummechanically : Quantumelectrodynamique + Quantumchromodynamique. : ' Think/Say never : " NO! "  !'
tempus, locus : in-/ syn-chronisity. ? Wormhole-theory. ?
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=https%3A%2F%2Fm.spiegel.de%2Fwissenschaft%2Ftechnik%2Fphysiker-melden-neuen-quantenrekord-2000-atome-an-zwei-orten-a-1289502.html
Object. ( virtual)  INTERFACE Human
Subject ( virtual)  INTERFACE Human
Object INTERFACE Subject
Subject INTERFACE Object
                   physical " moment " : external or internal impulse ,actio/reactio angle as ° and direction ?
                 movement : not communication ? attraction !?  rejection !?   resistere / sistere
                                     center/ nucleus/core      near/er             far/er
F.e. : a 2 in x 2 in x 2 in N52 Neodym "supermagnet" becomes cutted into 500 0,1 mm thin film plates/foils andthese enroling to tubes :  + / positive pole  and - / negative pole per side
these tube(s) now enroling to a donut : plus/ minus pole  ? outside/inside polarisation. ?
ayeaye
citfta,
I have also spent many hours working with interaction of magnets and with the theory of overunity about the magnetic fields and also in solid state devices, also posted this and my videos here. I show here only my this drawing  https://ia800903.us.archive.org/22/items/Flcm4/pmmbp12.jpg . This shows how the asymmetry of the magnetic field (two poles) can enable overunity. In theory any asymmetric field can do continuous work, this is one way how a magnetic field can do it. I'm sure that the effect that you showed is based on the same asymmetry. I have not thoroughly analyzed your case, but i showed the theoretical reason in the simplest case, involving only two magnets.
I read the Floor's pdf-s, they were very long and seem to contain a lot of useless information. I maybe couldn't find the essence in them that made you to do your experiment, but i likely didn't read them thoroughly.
But you hit the nail, the matter is that you did hit the nail, not Floor or anyone else, though the contributions of others are certainly important.
I see that this is important not only about the magnets, but for the theory of overunity in general. More work should be done on that theory. Because i see that the reason for overunity is always the same, it is that the electrons orbiting the nucleus of an atom don't fall to the nucleus, even when they do work. No matter whether the device is magnetic, solid state, or even mechanical. I also explained the reason why for that reason the energy may come from the zero point and go back to zero point. Every time a field does work, even when you drop an object and it falls to the floor.
ayeaye
This is the diagram of the citfta experiment, see the citfta'a las video with measurements. The diagram was made with dia.
citfta
I have been doing a lot of testing of an idea Floor presented in this PDF: 2 Mirror Engine.
I have attached a copy of it to this post.
I believe from my testing this idea may be the most important idea so far presented by Floor.
I highly suggest you study it carefully.  Especially the section about the thickness of the metal between the opposing magnets.
Respectfully,
Carroll
