Magnets, motion and measurement
Started by Floor, October 31, 2016, 09:11:43 PM
Floor
@ All readers
What's in these PDF files ?
Simple and easy to understand drawings and explanations.
The how and why of magnets from basics to fairly complex.
A suggested order of reading
Magnets Motion and Measurement part 1-6-2.PDF
Magnetic force Measurement.PDF
ForceGraphing 2-2c.PDF
Diminishing Return 2-2b.PDF
InverseSquare 1bPn.PDF
InverseSquare 2G2Pn.PDF
MagnetBasicsCombined 1-5.PDF
Mirror Engine 4new 1, 2 and 3 PDF files
La fonte Pseudo Solid Motor V2 PDF
La Fonte Pseudo Solid Explained 7 PDF
Explains some basic physics and is written for people
interested in doing home experiments related to alternative energy.
In particular, it is written for those who have an interest in magnets
and their interactions.
                        TOPICS COVERED
ENERGY, INERTIAL FRAME OF REFERENCE, SPEED, VELOCITY, GRAVITY, FORCE,
ACCELERATION, THE FORCES OF ACCELERATION,  CONSTANT ACCELERATION,
ACCELERATION BY GRAVITY, INERTIA, MOMENTUM, MASS, WEIGHT, MASS V WEIGHT,
THE NEWTON, WORK, THE JOULE, ASPECT RATIO, TIME, POWER
How to measure / determine the amount of energy in simple magnet interactions.
Calculating displacement and force inputs and outputs as energy.
Examples of how to calculate the amount of energy in displacement and force
interactions.
Intended to give the home experimenter some idea of how much precision to use
when measuring magnet interactions.
A fairly detailed explanation of what the inverse Square law is.
This applies to magnetic force decreasing as the distance from a magnet increases.
Explains magnetic domains, Bloch walls, certain other aspects of magnets which an
experimenter will find useful. Some little known magnet interactions, facts and
explanations.
An informative study of magnets interactions and Over Unity.
La Fonte Pseudo Solid Motor V2 PDF
A design as explained to me, by user GammaRayBurst at the OverUnity.com forum
To my knowledge, no one has to date, measured the work in to work out of this design.
An interesting and illuminating set of designs, magnet interactions / principles
also as explained by user GammaRayBurst at the OverUnity.com forum.
Floor
@ all readers
Please find the attached PDF files
Suggested order of reading
RightAngleSlide.PDF
MagneticForceNeutralizer 1.PDF
Rack action.PDF
ForceBalancingVariations.PDF
CombinedNeutralizedUnits.PDF
Floor
telecom
Sounds interesting, but have you tried doing the actual measurements ?
Floor
@Telecom
QUOTE from Telecom
  "Sounds interesting, but have you tried doing the actual measurements ?"
END QUOTE
What is it that you find "sounds interesting" about the presentations.
Have you ever presented a similar measurement process, here on the OU forum ?
             If so What measurements would you like to see ?
             If so will you describe for me, a precise set of measurement procedures which
             which would be adequate to hold your attention ?
What tolerances would you consider as adequate and why ?
@ All readers
About the PNG file immediately below ........
Don't read it if:
1. you're not in the mood for some deep thinking
2. you're at a location where it might be deemed as inappropriate
    if you are laughing out loud.
             and please
                   remember to share
                                      floor
