Why Over-Unity is Possible
Started by pauldude000, November 16, 2016, 09:39:04 PM
Low-Q
Quote from: forest on March 13, 2019, 02:42:47 PM
Some inventors from the past stated that electric generators do no convert mechanical energy into electric current. Such opinion looks crazy to us but after investigation I take it seriously. There is no direct relationship between magnetic field produced and the input power of electric circuit. Ampere turns and mass of the iron core is the only limit.I believe now ,that generators do not convert mechanical energy into electricity, they condense magnetic field lines into electric current, probably taking the excess from external Earth field.It's so intense that even now I still need a proof and sometimes lost my conviction....sadly I don't expect anything to change in near future - probably no scientist would take it seriously without strong proof.
But it's here, it's a very important concept and it may save the world
Hmmm, If it works as you suggest, all generators and motors should have saved the world since Tesla invented the AC-generator. Just because possible discoveries is not known untill today doesn't mean that they did not exist before we discovered them.
What I do know, is that the mechanical energy you use to turn a generator match perfectly to what you get out in electric energy. So I cannot say there is any significant difference between the two that will save the world.
However, you are a free man, and free to believe what you want, but please don't say you believe that the earth is flat...(Pun intended)
Vidar
Tito L. Oracion
The real reason why free energy is possible because electrons are almost no weight.
Weight is just apply when there is an essence of gravity.
That is why earth is floating and it has no reason were to fall even it want,
Therefore we conclude that there is no such thing as weight just pull.
And therefore the continues pull makes a movement and creates free energy and also there leads to free energy or overunity. Whoooooh
:D ;D 8)
It is a matter of pull and push why things possible. A really just a matter of concentration. 8) ;)
Free tits ;D
Cherryman
Quote from: Tito L. Oracion on March 15, 2019, 07:02:25 PM
:D ;D 8)
Free tits ;D
Excactly!
It's just a matter of finding the nipples!
forest
Low-Q
"What I do know, is that the mechanical energy you use to turn a generator match perfectly to what you get out in electric energy" - what physics law describe this ? Can you find exact one explaining why mechanical energy should be converted into electric energy ? It is an assumption.The only applicable is Faraday law but where does  it state that mechanical energy is converted into electrical in 1:1 ratio ?
The mechanical energy of current generators are used to fight the attraction force between two electromagnets of running mass of iron. The more the output the larger field produced the bigger attraction then more mechanical force needed to turn shaft and mass of iron of generator.As simple as this. Measure the field intensity of loaded generator and construct the bigger one with more iron mass but without moving anything except the output coil.
