TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
Quote from: gotoluc on December 30, 2016, 10:08:53 AM
Hi Lota,
It is not clear what you are trying to say.
Are you saying without continuous movement or rotation there is no power?
If so, I agree.
My test device is not made to measure power at this time. Those tests will come in the future rotation device.
Actually, torque is a kind of "power", except that instead of acting across a time period (like Watts acting over seconds to give Joules of energy) it acts across angular displacement (torque acting over radians to give Joules of energy).
No, you don't need to show continuous rotation to demonstrate power or even overunity. Although it would do, if it did!  If you can show an _energy_ surplus during part of a cycle, even if it gets eaten up by mechanical losses in another part of the cycle, you still may be able to show OU without continuous rotation. And you would have a target to aim at: further reduce the losses in the lossy part of the cycle!
All I'm doing now is trying to find the most efficient magnet geometry.
Since the beginning of my tests this is the first time I'm measuring such a great improvement.
Glad you to see an excellent builder like you is looking at this.
Looking forward to see your build
Luc
Thanks for your input and support Carroll
Luc
Great!
As long as you realize what lota, DRJones, and I are trying to point out about the difference between torque and energy (work), since it is possible to have an increase in torque without having an increase in energy.   ;)
gotoluc
Quote from: lota on December 30, 2016, 02:12:35 PM
I mean: work in must be greater than work out.Not the strength.
Humm :-\ ... if work in is greater then work out, how do you achieve OU?
I'm building a machine. A combination of gap power and this magnetic system to a generator. I'm thinking, how do I get a continuous rotation. Gap-Power is for linear drive to the magnet.
Ah, Gap-Power of Art Porter. He is a very good and generous man. I went to his home about 2 month ago. We looked at his devices and he let me bring back his first device (aluminum table) which I temporarily modified to test floor's research.
He has also given us an extra coil and magnet set of his latest device used in the video you mentioned.
It's true that you can use magnet in conjunction with electromagnets to more then double a electromagnet magnetic field strength. However, what is not apparent to many experimenters at first (including me till a few years back) is the counter electromagnetic field (CEMF) also doubles in strength which bring you right back to normal electromagnet behavior and is always under unity.
I know for sure as I've tried to beat this for years without any success.
The effect of CEMF was very apparent when I built a super build of my "Mostly Magnet Motor"
The bottom line is, as soon as you turn on a coil (no matter how short the on time or multiple pulses used) if there's a moving magnetic field no matter how powerful your magnets are, you're dead at that point.
Here is a shortcut to understanding the device and the end results: http://overunity.com/8429/mostly-permanent-magnet-motor-with-minimal-input-power/msg420188/#msg420188
Luc
gotoluc
Quote from: TinselKoala on December 30, 2016, 04:58:57 PM
Thanks TK for trying to clear the miscommunication.
I do know that continuous rotation is not needed to demonstrate OU. That was not what I was trying to communicate.
Yes, I also know and agree that an increase in torque does not mean an increase in work. I'm not aware that I have been demonstrating or indicating this anywhere!... if you do see it somewhere, please let me know so I can correctly explain or correct it.
Thanks for your help
Luc
lota
Hello Luc,
It's nice that you talked to Art Potter. A friend of mine is building and testing its solid stat machine. We will see what he can find out. I would like to test this project and this https://www.google.de/?gws_rd=ssl#q=Kedron_EDEN_Project.ppt.When I'm done, I'll show it.
I wish all a healthy and prosperous new year.
Lota
synchro1
Quote from: gotoluc on December 30, 2016, 08:58:44 PM
Luc
Look at this "Flux Gate Ladder" below:
