TD replications
Started by Floor, November 18, 2016, 11:14:23 AM
telecom
Hi Luc,
the actual gain , I think, is 2 times higher than you calculated because
your output goes back and forth during the cycle, so the total distance
is 22 mm by 540 grams = 11880 gram x mm
telecom
Considering that the input is 3700 gram x mm per cycle,
you have a gain of 3.
Floor
@GoToLuc
                 very nice work
                           thanks
                                floor
gotoluc
Quote from: telecom on February 09, 2017, 07:21:16 PM
Hi Luc,
Hi telecom,
It would be great if there was twice the movement. However, I don't see that.
I made a video just for you to count them.
Link: https://www.youtube.com/watch?v=dpBaeJD38HI
Luc
gotoluc
Quote from: dieter on February 10, 2017, 11:40:17 AM
What is still a question is how the 11mm push is measured over that distance, with the wheels' magnet aligned in the center, or with it passing by.
Since the device is very dynamic the only way I could measure it was to do each step at a time. So to answer your question quickly, the 11mm stroke is measured once the rotating magnet is centered with it.
Luc
