reasoning
Started by that_prophet, November 24, 2016, 03:24:53 PM
that_prophet
this works by only putting one spark of DC current into your DC motor
which rotates a 100 cnn pulley one full tinne = 100 cnn of moving belt
which passes by 10 nini-pulleys = rotating 10 AC generators =(free running = no load)
think of the AC generators - with no load on them = only one spark is needed to be generated
(which is practically no current + only winding up massive voltage)
torque is caused by generating power = Volt x Anp
that_prophet
if you attach a 100cm circumference pulley to a DC motor
it only takes one spark of DC current to rotate a DC motor one full rotation.
this would give you 100cm of moving belt to work with
now if you run this length of moving belt past 1to10 mini -pulleys.
of one centimeter circumference with AC generators attached to each pulley
then you would get 100-1000 units or cycles of AC electricity.
these are free running AC generators=(as no load is on them)
all of these generators are running with zero load = no electricity being used
just the fluid friction of the bearings is your only wear or load-type
but you could use magnetic bearings + have zero friction
so all of these AC generators are just winding up massive voltage
which can be accessed as potential = ability to do work = available current in load
you have just made your first self powered set of running AC + DC generators
that you could tap power off of + the more mini-pulleys with AC generators attached
the greater amount of current you should be able to do work with
(now.... don't you think that you could be able to get one spark of DC current)
( out of the 1000 units of AC electricity that you have for an output)
(this would make this unit a self powering mechanism = perpetual motion)
(+ this could be producing an unknown amount of AC + DC electricity)
http://free-energy.yolasite.com/ = PUBLISHED IN EARLY 2000's
(YET THERE IS SUCH A SPIRITUAL WARFARE GOING ON AGAINST IT)
((( evil spirits were hiding this tech = lies about torque being a problem )))
Now comes the bad+scary part of this awesome free energy technology discovery
You can easily see just how super simple this AC multiplication technology is
so why could not any one of the millions of above average intelligence have discovered this
long ago... as soon as AC electricity was discovered. Well this is hard positive proof
of there being powerful spiritual warfare going on all around us... + they were winning
I would say that these powerful evil forces were winning - if they could hide this from  us
I happen to be Born Again-(28-11-88) + want this super simple free energy technology known
long before the first Door closes for Christ's return in the clouds by or before 2019.04
http://doorschristmustpassthrough.yolasite.com/ + http://2020-vision.yolasite.com
This technology is in the Holy Bible = in Ezekiel 1:16
where he is describing what a UFO motor looks like while it's running
so this technology will eventually lead us to anti-gravity
as well as not only speeds approaching the speed of light
but also the ability to do 1000 kph vectoring
We are warned that no one knows the day nor hour... (Mat 24:36) but it says that we will know
when it is near... near to what? maybe the door.... as we can know when it's"even at the doors"
(Mat 24:33) + I heard that in the original Greek it was worded like a command "know that it is near"
With this technology the Tribulation Saints can keep warm in our cold Canadian winters
even off the power grid. (remember the heat + light of fires would easily give away
your position visually... as well as via satellites)
notice that Doors are plural - because He show up twice =
1) - Rapture = "caught up together with the in the clouds"-(I Thes 4:17)
2) - "Glorious Appearing" at end of Tribulation -(Titus  2:13)
I DO NOT KNOW IF I BE THAT PROPHET OF THE BIBLE... BUT NOBODY ELSE IS SHOWING UP
. . . ( + there are less than 3 years left before the door shuts + Christ MUST come back ) . . .
. . . . . . ( + He has shown me a few Biblically significant things= 'I am" + 2020 Vision ) . . . . . .
. . . . . . . . . ( to find out more GOOGLE beliefstoliveby + yolasite = 30 + websites) . . . . . . . .
