Earth Energy Batteries
Started by FreeEnergy, April 20, 2005, 08:31:00 PM
guruji
Quote from: Rapadura on February 21, 2010, 09:55:31 PM
OK, I need to ask:
Has anyone managed to connect two earth batteries in series and proved that the volts of each battery were added?
Has anyone managed to connect two earth batteries in paralel and proved that the amps of each battery were added?
Hi Rapadura I did two earth batteries and connected them in parallel and yes it seems that amperage will double. My earth batteries are not very efficient I can say but I'm noticing increase in voltage everyday. If one make them according to many guys did here in this forum they will acquire much more than I did cause I only used copper and aluminium in mine and one of them put a little steel wire.
Thanks
Rapadura
I hope some day someone posts a video on YouTube showing a 45 watt fan running at maximum speed, powered only by an array of earth batteries.
That should be cool!
winn1971
the_big_m_in_ok
Quote from: winn1971 on June 28, 2010, 09:25:06 PM
how come i can't open the first file?  i'd like to try this experiment but everytime i download it kept saying that the file is damaged and cannot be opened.  thanks.
That file is:
http://www.site-city.net/internett/softnice/tech/free_energy/free_energy_from_the_earth_plans.pdf
Alright, the file is gone.  I see a blank white screen.  This is probably the reason:
http://fliiby.com/file/247453/q8gzttlqru.html
Someone complained about copyright infringement.
--Lee
the_big_m_in_ok
Quote from: the_big_m_in_ok on June 28, 2010, 10:22:49 PM
That file is:
LATER REEDIT:
The second time I tried it, the error message said, in effect:
"The file is corrupt and cannot be repaired."
Same thing in the end.
--Lee
