Resonator Coils that put out Free Juice.
Started by FatBird, November 25, 2016, 01:35:25 PM
Zephir
The author of resonator hides the additional battery in the multimeter, which was supposed to measure it instead of powering. He revealed this fact by accident at the end of one his videos, so that he reuploaded it and subsequently switched YouTube account - but I already had a backup Tech troll and Experiments Lab are the same person from Czechia, Experiments Labs hides it by wearing of gloves and by commenting his videos only with subtitles. At any case, once his generator utilizes electrosmog, then it doesn't run on the free energy.
 :o At any case, once his generator utilizes electrosmog, then it doesn't run on the free energy. ???
                         http://www.detect-protect.com/k/buzz/whatiselectrosmog.htm
        Zephir,could you explain me(and probably also others) what "free energy" is or should be ?
                                                With or without "Gibbs Theorem" !
   I think under the battery use condition then it would not be the case to work as "free energy converter"
   but by electro-smog absorving and converting this would be the case, working like a RF-nantenna !
   Sincerely
               OCWL
p.s.:
                                                     http://www.rexresearch.com/rodin/7-bearden.pdf
                    terrestric: bi-/unipolar   https://en.wikipedia.org/wiki/Oudin_coil
                                              orbital/astrophysical (coil included texturated as coil-array foil)
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=joseph+yater&IN=&CPC=&IC=&Submit=Search
go to description translator
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=siegfried+stargard&IN=&CPC=&IC=&Submit=Search
especial "Augenmerk 8) Marconi/Ferrari,Tesla Tower"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940630&CC=DE&NR=4244447A1&KC=A1#
and the amplifier
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=24&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920827&CC=DE&NR=4106043A1&KC=A1#
Zephir
QuoteZephir,could you explain me(and probably also others) what "free energy" is or should be ?
Free energy is not supposed to utilize (only) the electrosmog, generated with people, it should run at Moon or Mars too. But the TechTroll/ExperimentsLab's "device" doesn't even utilize electrosmog (it has too much of power for it, after all) - but tiny flat lithium battery. At thicknesses of 0.5 mm, these coin cells are used in non-contact cards and ID tags.
