The Concentric Capacitor - Key to the Kapanadze Device and similar FE Concepts?
Started by Zeitmaschine, December 16, 2016, 04:40:24 AM
antimony
Zeitmaschine
A classic Leyden Jar perhaps? :)
QuoteSplitting the positive source away from the negative source appears to me
to be the correct approach.
This results in a high voltage source with infinite resistance. How to accomplish this with traditional circuitry? Maybe a high voltage transformer with two high voltage coils, each has one lead connected and one open, one connected lead is positive and one is negative?
And I'm still waiting for parts from China ... :(
Zephir
In dense aether model the vacuum behaves like elastic material, similar to foam. The foam can mediate both the transverse waves (which spread in similar way, like the ripples at the water surface), both longitudinal (scalar) waves, which could be imagined like the pressure waves of the underwater. The common antenna dipoles are supposed to radiate transverse waves only, the radiator of scalar waves should consist of just two concentric spheres with alternating voltage between them - i.e. just like the concentric capacitor. The concentric capacitor is the electrostatic analogy of bifilar coil in electrodynamics - this arrangement of electrodes is not supposed to radiate the energy into an outside, because the spherical antennae aren't supposed to radiate in Maxwell theory due to charge conservation.
What makes this arrangement interesting for overunity forum is, that the device which can radiate some wave can in principle serve as a detector of them as well. And the vacuum is supposed to be a full of scalar waves, which manifest itself like the quantum fluctuations. The transverse portion of these fluctuations is detectable directly even with common antennae like so-called microwave background radiation. And the scalar wave portion should be even more intensive. The point there is, the charged capacitor should serve like the rectifier of electric field formed with these fluctuations, because its voltage drop creates the similar space-charge like the  space charge region at the PN junction of semiconductor diode. On this principle so-called captret is reportedly working.
worldcup
Quote from: Zeitmaschine on December 16, 2016, 04:45:41 AM
More attachments.
Slightly off-topic, the Lüling permanent magnet motor (similar to the Perendev motor principle, similar to the Ylidiz motor principle), presented in the UFA-Wochenschau 498/1966 (click the play-icon next to 'Cut 1'), vanished since then. Because magnetism is also a property of the Aether, it is reasonable to assume that a permanent magnet motor has to tap into that source of energy as well, although the method is different. The method is to shield (neutralize) the magnets properly, so the magnetic field remains in a constant state of imbalance. However, that creation of imbalance in the surrounding Aether should also be the basic principle of Aether powered electric free energy devices.
And since this is all about warping the Aether but not the pages of this forum due to oversize images (greater than 800px width), the solution to that is a Firefox plugin called Stylish. Just in case we copy the following lines into that plugin:
@-moz-document domain("overunity.com") {
  .attachments,
  .post {
    width:805px!important;
    overflow:auto;
bump... seems interesting photos are attached in original post..
