Smudge's Musings on Electro-kinetic Potential in the Earth’s A Field
Started by ramset, January 06, 2017, 09:33:20 AM
Dave45
The A vector field runs outside an air cored coil but if a ferrous core is added it pulls the field in close to the core. The field is pos so will be attracted to a cap with one leg attached to ground.
Im glad someone is realising this is the field that is responsible for energy exchange. Of course it is relative to the magnetic field so all calculations work.
The testatika has an air core coil in the center of the wheel, the vanes run in an collect the A vector field of this coil.
The current run through the coil is dc, a coil powered with dc will have a centered spiral field, a coil powered with ac will have a broad erratic field.
shylo
Hi Dave, So if the coil is AC does that mean the field now swings pos to neg ?
With a half bridge on each coil lead you can now charge 2 caps?
Thanks artv
Dave45
Dave45
This is how to pull energy from a dc powered coil without pulsing it.
Its ironic that we have been using wind mills for years and now an electric mill is the answer we need.
No ferrous material around the coil, you want the field to run outside the coil in the path of the vanes.
Dave45
If we think of earth as a magnet the magnetic fields run south to north so telluric currents run west to east.
