Why Is AC-Current More Efficient Over Long Distances ?
Started by guest1289, January 13, 2017, 03:13:23 PM
wattsup
@for the question - a different view
DC is like having two water hoses open at the same time. That's why most dc coils when they burn up do so near the center point.
AC is like one hose is a drain open to the atmosphere, and the other hose where during half a cycle it pumps and during the other half a cycle it is in suction and this creates a STATIONARY change via the inertial changes being seen by our slip rings like a one directional ratchet where one way or the other turns the socket in the same direction.
Both types never really pump but DC is dual push, ac is single push/pull where in both cases there is never any real FLOW of anything. There is only a conveyance. Like when you go to a huge stadium and see the human wave where people stand up then sit as the wave point passes them. The wave is conveyed but no one really moved out of their position.
There is no such thing as alternating current in the sense that we have been taught that the output is on the hot for half a cycle and on the neutral for the other half a cycle. Try and prove me wrong. hehehe
DC is more of an adversarial power source with both sides looking to take over the pulsed object where as AC is more of a one handed taunting of the coil. Tesla, if he took the AC further would have invented Dual AC but there was no need for that then and 180 degree offsets where not easy to make.
AC should be called Single Wire Seesaw Current. Or you can call it also Single wire Push/Pull. That's why AC can be conveyed for such long distances because the higher the applied voltage the deeper (or further) the conveyance can reach without too much loss. Voltage is distance. Amperage is the number of atoms involved in the distance conveyance. A concept thunder (or your spark gap) has learned long ago.
If in these simple DC to AC comparisons, some here can jump the fence from the Standard bullshit to the new side of the fence, you will start to see effects in a totally different and more direct and realistic manner. You will soon then realize that all this electron/field crap we have been fed was only an illusion reinforced by our normal desire to manifest notions in our minds in the most accepted form as being "SAFE to talk about".
Our present notions are only accepted because peoples jobs are at stake, and regardless if society is following a false or true concept, the toys still work. But in order to arrive at a next generation of toys, if the concept stays the same, there will be no next, there will only be a continuation of the same. The same road leading to the same losses while this other road will lead to OU, levitation as being an atomic inertial effect and NOT FIELD RELATED, new types of wire with more oriented atoms producing hyper super conductivity at ambient temperatures instead of requiring absolute freezing to produce what we call super conductivity today, is just a furt in the windstorm.
With the new notions, we will build transformers with 1" long secondaries directly going to load. With the new notions, EE math will be simplified to its extreme. Electrical potential will be seen as degrees of nucleic sway, materials will be chosen for their nucleic reactance, this will change how we see mass, our bodies, liquid, gas, plasma, will all be seen in a new light. Xrays will finally be seen as an inward effect and not this outward radiating ray that cuts through everything organic.
But you can only realize you need to look elsewhere when you arrive at the edge of the forest understand that your world is much greater then the barren outskirts of your domain. Only if you thirst for something that you know in fact has to exist in another manner then how you see it today. It requires a WILLINGNESS to push your mind out of the stranglehold of present concepts. There is no other way. A pill won't do it, watching TV won't do it, going to work won't do it, even praying 10 hours a day won't do it. Only your mental intention to push yourself beyond your present limits will even start to kindle the fire that can then grow inside you as a new method of normality. The toys will stay the same for a while, but then, they will morph into quasi living entities with reacting atoms at every nick and cranny of the object.
Happy New Years 2017 to all.
wattsup
citfta
Quote from: Magluvin on January 16, 2017, 12:50:17 AM
Skin effect is more at high freq, not at 60 or 50hz, I believe.
Havnt tried it yet but say if we have to run an extension cord 100ft from a 120v AC outlet to run a 300w halogen work light.  If we replaced the extension cord with 2 separate wires that were say 3ft apart for the 100ft, would there be any change in power at the light in these 2 situations?  Lets exclude the 3rd ground wire for this idea.
I am thinking that when the 2 wires are close together, even twisted pair as in the extension cord, would transfer the power to the light better than the separated ones, and the mutual induction of each wire to the other compliment current flow, where the separated wires would have to deal with their own self induction possibly reducing the output to the light in comparison.
Mags
Hi Mags,
You are correct that running single wires that are separated would not transfer the power as well as a regular extension cord where the wires are next to each other.  But the reason you are correct is not only what you surmised.  The wires running next to each other also cancel the inducing ability of each other.  I once saw a machine designed by an engineer that was not familiar with this function.  He ran the three different phases of power in three separate conduits.  When the machine was first turned on it started making a very loud humming sound and the conduits started smoking.  Each phase being in it's own conduit allowed those wires to induce tremendous eddy currents in the conduits.  We had to completely rewire the machine before it worked properly.  In your extension cord example the returning current is cancelling the outgoing currents magnetic field and therefore there is not a strong enough field to induce eddy currents in any nearby metal objects or in any metal conduit if conduit is being used.
Carroll
AlienGrey
Because it is an action of the active motion of the sine wave it's dynamic it needs some where to go or disparate, it's realy obvious with the way it's generated. Eric Dollard is your man he explains it in one of his videos. If i shoved you in a tube and kept shoving things in behind you you would have to move along or out the other side or bang you explode into fragments AC energy is the same.
Dave45
I was playing with small ring magnets letting them spiral down a welding rod an notice they would want to change direction before they reached the bottom, it was like the field tightened up if it only spun in one direction, at least that was the thought that came to mind watching it.
Also if you try to push a wire through a.conduit it tightens up but if you push and pull it moves through the.conduit much easier.
