Magnet force shield
Started by Floor, January 21, 2017, 11:14:49 AM
Floor
Here is a design for neutralizeing the magnetic force,
with an attraction based output.
These designs, devices and inventions are given into the public domiain.
note...since these are devices intended to give OU, one can reasonably assume they are
not previously pattented ?
                       floor
Floor
Note...
I hve not put this last design (shielding with attraction as output) on the bench for testing yet.
           regasrds
                    floor
dieter
Thanks for sharing these very clear drawings. I've seen the vid, which is impressive. Also in the light of Luc's latest measurements, very promesing.
I wonder how would you implement the work cycle in a rotor, or are you preferring a piston design (which would be much simpler I guess)?
Floor
Hi Dieter
         I'm still looking at the design @
http://overunity.com/17070/all-magnet-motor-td-based/
         I have some of the materials for a test build.
         I need to wet cut some ceramic magnets on
         the diamond wheel.
         Modify / cast some plastic gears (2 crown and 2 pinon gears)
         But for now I'll stick with the linear motion sets.
                              my  projects
         Installing some flooring (paid project).
        I would like to do a full measurement set for Gotoluc's design (scaled down) ....
        before doing measurements of any of my new designs.
                                               But first I'll need to ...
  detail / ask Luc to  check out  the magnet start and finish positions for that measurement process.
        There is yet another 3 magnet interaction set I want to diagram.
        I want to redo / finish the next section of the "Magnets Motion and Measurement"
        book / topic...... how to integrate a magnet force that is changing with distance and
        how to calculate the work done as joules and so on ................
                         regards
Floor
addendum
One more drawing for the attraction based output design....
        thanks Dieter
              floor
