Is anyone seriously interested in Free Energy Physics?
Started by aether22, January 22, 2017, 05:31:43 PM
aether22
Smoky2, I realized there is a difference between "I don't understand your description" and "I am not sure if I have this right".
So here is my guess from your description..  Please tell me if this is it, close, or totally wrong?
sm0ky2
Quote from: aether22 on February 07, 2017, 08:37:37 PM
I'm going to say totally wrong with respect to the trillies
As well as the second image.....
I could maybe draw it out later but I'll try for a verbal description
Stand all the pieces of tube upright in a circle
Sort of like the bottom half of the second image
Touch them together all except two. Leave a tiny gap.
Now wind two opposing coils linked in series.
One north and one south, wrapped around the tubes facing the gap
With a quick pulse from a battery, the tubes will magnetically lock
Just like Leedskalnin's PMM
You can cut the coils off or unwind them or leave them there
Magnetic current flowing through the metal will stay in
Perpetual motion until you break the loop.
When you break it, electromagnetic field will expand
Then collapse. Almost the inverse of the original pulse.
aether22
Quote from: sm0ky2 on February 07, 2017, 08:52:32 PM
Ok, so are there permanent magnets?  Are they inside the tubes pointing out radially?  And these comprise the rotor?
So there is some number of tubes and coils wound over the tubes with the coils wound over the gap in each tube, with alternating current direction in adjacent cylinder?
Here is another image, it shows vertical cylinders, with the splits pointing out, and coils wound on top of the cylinders over the gap, here shown as just the cross section by white bars at the sides of the coil.
You say the tubes/pipes/cylinders are touching, but if they have coils wound in the way it sounded than it would be the coils touching.
Also how many cylinders are there?
Is this a motor?   Is there a rotor with permanent magnets above or inside this thing?
aether22
I am thinking maybe the guy is David Lambright?
http://overunity.com/9603/a-new-kind-of-visible-radiant-energy/
Also when you say PMM, I wonder if you mean PMH, Perpetual Motion Holder, the name Leedskalnin gave to his closed soft magnetic circuit that would hold a magnetic field until the circuit was broken?
sm0ky2
No there are no magnets
It's a perpetual electric effect in the magnetic domain
The steel tubes act as magnets until you break the circuit
