Is anyone seriously interested in Free Energy Physics?
Started by aether22, January 22, 2017, 05:31:43 PM
sm0ky2
Did the tube pieces magnetically lock together
When a short Pulse (D.C.) was placed across the coil?
Curious to see if you got one coil to work.
In theory it should (weakly).
In practice two coils are generally used.
aether22
Quote from: sm0ky2 on February 10, 2017, 02:33:13 AM
Yes it worked, they snapped together.
It would work stronger if I wound it over the whole piece.
Maybe I should.
sm0ky2
I found Daves YouTube channel
https://youtu.be/_8X-kY1o1L0
I didn't replicate all of his work,
But I was able to verify some visual
Distortions.
(Magnetic refraction?)
And several magnetic anomalies
The tubes were just a small part of what he got into
His experiments literally transformed our knowledge
Of the PMH
sm0ky2
I show this here becaus in an odd way I find the two
subjects to be closely related.  PMH's occur in nature
When there is a ferromagnetic loop and a magnetic flux.
The loop can trap the flux in a perpetual state.
When the loop is broken, the original flux is released.
It's amazing to realize that this just happens.
We have found PMH's to exist in steel door frames
Parts of elevator systems, giant sandstone outcroppings,
Piles of junk metal at the scrapyard accidentally PMH'ing
I wouldn't be surprised if there were an actual lifeform
That existed in this state.
sm0ky2
Quote from: aether22 on February 10, 2017, 02:37:15 AM
Maybe I should.
I think it works best when one coil is on the piece of tube
To the left of the gap
And an opposite coil is on the piece of tube to the right
This way when the coils are charged up, the magnetic
fields are facing each other n><s
This provides for a stronger magnetic current
As many PMH builders have shown, it can be done with
only one coil, or when you get good at it- with the brushing
or close passing by from a permanent magnet.
But I have found the double-coil set up provided by Ed
To create the strongest locking effect, and field return.
Which are the two primary criteria by which I measure
magnetic current (or quantity storage) in a PMH.
