Sm0ky2's modified Voss Machine
Started by sm0ky2, January 23, 2017, 03:08:32 PM
sm0ky2
Someone in the other energy group was asking about
my machines "running in reverse".
Apparently there was some confusion about how it can induce
with the polarities switched like I do.
So I wanted to take a moment and clarify what I mean when I say
what is important here is not the reversal of polarities
But in how the charge is flowing through into and out of the device.
In a standard old-world induction machine: electricity is induced by moving
opposite charges past one another and sending the excess induced charge
out to the terminals.
My machines run in reverse:
Charges are induced on the large plates by passing LikE charges past one another
with a dielectric charge zone of opposite polarity between them.
The charge being picked up by the terminal brushes comes directly from the plates
via the plate brushes, then is amplified before it is picked up.
That's why I don't need a neutral bar.
Current isn't flowing "from" the device, the device draws current "from the environment"
by maintaining a potential at the terminals.
The environment is constantly trying to balance out the charges on the plates.
I can run two independent (and opposite) current streams from almost any object
to either terminal.
sm0ky2
I made a little 12 min discussion video to try and explain
the Ion Generator technology.
Hopefully this will help those interested to understand the machine
Before I get too far into the new model, as one would need the basics
to move onto the more advanced machine.
https://youtu.be/W_Q7erF1UEw
If anyone would like help replicating the modified Voss experimental test machine
I can walk you through any issues you may have.
I will post detailed plans of the new Ion Generator 3.0
Once I have sourced the parts for the new build.
sm0ky2
Update on my progress::
I added a new insulation layer to the large plates
And recovered with with a fresh layer of aluminum duct tape
Balanced the cylinder a little better and
repositioned the plates as close as I could without scraping
Switched back to the low friction brushes
And adjusted the resistance to get a steady speed
Then adjusted the spark gap until the machine stabilized.
Here's a video of the first test run, using 4" spheres
The spheres double as capacitors,
Don't worry this one is only 45 secs
https://youtu.be/ID2hKBlNiCQ
sm0ky2
Number One
Take us to Impulse Power
https://youtu.be/ZFVlfwNlZAo
https://youtu.be/WOyCS2pQanc
There you have it, proof of concept.
The Ion Generator powering an Ion Propulsion Engine
9v @ 181mA DC
