Pyramid for electrical experiments.
Started by aether22, January 26, 2017, 05:01:50 PM
aether22
Hi, I have made 2 improvements on the classic Pyramid form, this produces far more energy, you can make a quick demo version out of paper, just print up this design and fold, while regular printer paper works, thicker paper (or paste the print up on thicker paper) would not be a bad idea.
I made the first discovery by accident, I put 2 triangles together to show an idea for a roof and I felt energy come off of this half Pyramid form, much stronger than from a regular Pyramid.
*SECOND IMAGE BELOW
I tried making a pyramid with 3 sides and the energy was weaker, my hunch was that with only 2 sides the opposite corner was unencumbered and with 3 sides all corners had triangles in their way, I could feel that circular vorticies formed at these corners and room needed to be made for them (or a pyramid made from large tubes would be fine as the matter would be fitting the energy dynamic that was appearing).
So I made something like this...
*THIRD IMAGE BELOW
While keeping the base the same size, make the walls of the pyramid smaller so the sides do not meet.
Note that the remaining triangles have the same distance from each other up the pyramid, that is how you want the sides to stand, the same as if they were touching each other.
Here is a pattern.
*FIRST IMAGE BELOW
The more of the triangle you cut away the stronger it gets, within reason.
Just fold the triangle sides at the correct angle, again the triangles do not touch each other and they keep the same distance from each other to the top.
But I made another separate discovery, I have yet to make this and my printer needs more toner...  But here is another discovery I made about Antenna forms, so just cut out the triangles (faint grey lines so as to not mess with the antenna if you don't cut it perfectly) into this throwing star looking form, then fold it into a pyramid where again the triangles do not touch.
*FOURTH & FINAL IMAGE BELOW
It only takes a few minutes to make this and the energy is hundreds of times more intense that from a typical Pyramid in my estimation, and strong enough that many people, likely most people could feel.
I have not yet tried to source electrical energy from such Pyramids, but if you did manage to get electrical energy from a Pyramid, this one might enhance it hugely.
sm0ky2
What is the method for "feeling" this 'hundreds of times more energy'?
Can it exert a force on an object?
Does this object need to be organic?
Like a creature on a stick?
Alive or dead?
aether22
Quote from: sm0ky2 on January 26, 2017, 10:54:11 PM
Alive or dead?
HAHA, how could the creature answer if it was dead?
Actually that is a plausible way, hook a plant to a polygraph and watch for changes.
I do not know if it can exert a force on an object, Pyramids can be shown to do some interesting things.
Rather than ridicule, just print up that pattern, cut it out, fold it (maybe paste it on some thicker card stock for good measure) and see if you can feel anything from it?
It won't take more than 5 minutes, 2 mins if you don't use card.
Yes, the hundreds of times is a subjective rating of my own based on how strong I feel the energy from a ho-hum regular Pyramid and this one, maybe it is an exaggeration, maybe it isn't, what it is, is rough and subjective.
