re: energy producing experiments
Started by Delburt Phend, February 04, 2017, 09:31:19 AM
Quote from: Tarsier_79 on March 20, 2022, 12:37:43 AM
IancaIV, what point are you trying to make? Let us look at context:
Using online calculators:
https://www.omnicalculator.com/physics/free-fall
https://www.calculatorsoup.com/calculators/physics/gravitational-potential.php
https://www.calculatorsoup.com/calculators/physics/kinetic.php
The 140KG falls from 0.25m to achieve this speed. (343 J)
1kg can rise to 35m at 26.24 kgm/s, which also costs 344 J
There is a difference in momentum, bu where is the energy gain?
So unless I am missing something, it takes 51,200 J to "place" 310 units of momentum on 1kg. How did we magically transfer 310 units of momentum from a 140kg at 2.21m/s mass to a 1kg mass at 310m/s?
                            " 310 units of momentum and you only need 26.24 units " :  310/26,24 = ?
                            https://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg564829/#new
Short answered about "..... we magically transfer ....." .
magica,mysteria,Magister,Meister,Master             M.S.A. :   Master Science Administration ~ kybernetes
I can,if You want to introduce Yourself in deeper hyper/deeper physics ,in"Quantum-Mechanics"-Logics explain ,similar ,
                                                 but animistic language,less " swollen ":
https://www.google.com/search?q=stephen+hawking&client=firefox-b-d&sxsrf=APq-WBsymqOZRsoVgTxAIse7P4c6HbEUeA%3A1647771334635&ei=xv42YvapJoj87_UPtYW7sAg&ved=0ahUKEwj2pMnIutT2AhUI_rsIHbXCDoYQ4dUDCA0&oq=stephen+hawking&gs_lcp=Cgdnd3Mtd2l6EAwyBAgAEEcyBAgAEEcyBAgAEEcyBAgAEEcyBAgAEEcyBAgAEEcyBAgAEEcyBAgAEEc6BwgAEEcQsANKBAhBGABKBAhGGABQughYughg3BZoAXACeACAAQCIAQCSAQCYAQCgAQHIAQjAAQE&sclient=gws-wiz
        String to Point-Matrix
        https://en.wikipedia.org/wiki/Urelement
                              C.Colombo : chicken or egg                      hyper/deeper physics Dualism:   spin or point
or,going 50 years back to its/his,Otto Stein,first publication date :
german,deutscher,Sprache/language : international -multilingual -traduction available doing ?
https://www.yumpu.com/de/document/view/20184764/otto-stein-die-zukunft-der-technik-pdf
Sincerely and a sinfull Sunday wishing
OCWL
Delburt Phend
Kator01
Delburt
Excellent find.You are a keen observer. I am amazed of the different possibilities to fully transfer momentum of of a big mass to a much smaller one.
Lets calculate:
Mass of the knot including the fluffy part about 2 gr = 0.002 kg
Minimum Velocity according to Wikipedia: v = 342.2 m/sec at T = 20  degree Celsius
E_kin = 1/2 * 0.002 kg * 117 100.2 m_exp2/sec_exp2 = 117.1 Joule.........thats a lot
Remember: The fastest Pitcher can throw a ball 105.5 mph which is about 47 m per second and if you look at the ease with which this woman
                    throws the whip....
https://sportsnaut.com/fastest-pitch-ever-mlb-history/
There is one peculiar thing: as the wave rolles down to the end it stops its wave-like movement about 10 cm before the knot as then
the knot is accellerated to full speed like the head of a serpent.
Why that ?
Question : would the sound barrier be reached if the wave would roll down to the end ?
There is a small element in the construction of the last part of the whip which makes it work and these "smart three engineers have not figured it out,
they fully missed a key element of the "faster that sound-speed-function" in their experiment.
I will not reveal it...its a good excercise for sharpening ones observation-skills.
I call it "The serpents bite"
Mike_G
Delburt Phend
There is one point in the video (smarter every day) where they say that the sound barrier is broken before the end; that might put the mass at around 20 grams. Also think of the air resistance you would get at these speeds.
Kator01
Delburt,
everthing is normal, see here:
https://de.wikipedia.org/wiki/%C3%9Cberschallflug#/media/Datei:Shockwave_pattern_around_a_T-38C_observed_with_Background-Oriented_Schlieren_photography_(1).jpg
and the compare to first and second picture
Now the third pic : what does this woman hold between their fingers ?
with the fourth pic : what does the corde look like shortly before the bang
Mike_G
