SGWN Generator 300 KW
Started by franco malgarini, February 04, 2017, 09:51:19 AM
sm0ky2
And finally this video
https://youtu.be/vGun5athdfg
Which shows that it is the angular momentum of the rotating mass
That causes precession
When the applied force is applied
Notice how in the 2nd video there does not need to be
very much actual movement of the axis, only an applied force.
(in fact there is a slight movement, but it is very small)
And gravity has nothing to do with this. Despite what educated minds
will try to tell you.
The gyro does the exact same thing when rotated in 360 degrees.
Vertical, sideways, upside down, at an angle
The only thing that gravity does in the precession experiments
Is apply a force on the axis
Are we all ready to build our gyroscopic power plants now???
gotoluc
An interesting subject and effects.
The below video contains much information. However, is it correct?
https://www.youtube.com/watch?v=NNLk5G3hgRg
sm0ky2
So we spin up a gyro, and input a small force to begin precession
A gear, partially covering the perimeter of a wheel
Attached to the top of the axis, spins up a flywheel
While reducing precession.
The mass of the gyro is raised when precession begins
And drops as precession is reduced.
See the image below:
dennisforrest
Hello,
I found this patent:
https://www.google.com/patents/US7375436
I think it's another system (it's related to AAron Goldin http://www.rexresearch.com/goldin/goldin.htm), but there's something similar to SGWN, using precession to create energy.
I think SGWN "secret" it's not simply related to precession, because of the layout of the generator: thin and very high (6 meters).
A simple precession mechanism will be fat and flat (or circular), because the discs of gyroscope need to walk in a large circumference.
The key is to understand what is inside the cone.
denis
