The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
0 Members and 206 Guests are viewing this topic.
ramset
Thanks Grandma
Quote from: tinman on May 03, 2017, 09:02:25 AM
The MH test results.
A 100 ohm resistor on the ground side,and a 100 ohm resistor on the input side.
No difference in current measured.
If you want a good suggestion Brad it would be to take a step back and do a slow methodical frequency sweep starting at low frequencies to observe what takes place.  For example, if you removed the center resistor and set your signal generator to say 100 Hz, then it's pretty certain that the setup would be a dead duck.  At higher frequencies, is it capacitively coupling or is it inductively coupling?  The way to find that out would be to look at all the parameters at different discrete frequencies and see what trends take place as you try 100 Hz, 500 Hz,. 1 kHz, 5 kHz, and so on.  You can determine the frequency steps for yourself.
On thing is certain is that as the frequency increases the setup will start to "come alive" and if you carefully monitor things you might be able to determine what effects are taking place and when and how the apparent OU is manifesting itself.  This looks to be a study in the increasing effects of parasitic capacitance and inductance as the frequency increases.  The parasitic effects make it more difficult to do an energy audit trail just like the high frequencies make it more difficult to do an energy audit trail.
nelsonrochaa
Quote from: MileHigh on May 03, 2017, 10:11:38 AM
You stop posting crap like this about me.  You can kiss my ass.  I stand by what I am saying and it is true.  Threads get derailed because people chase after one thing and they forget the original purpose of the thread.
It's a nonsense clip that is just "show and tell" for an air core transformer and indeed it's only a bloody coil.  I told you already that a normal air-core transformer will outperform a bifilar pancake coil transformer and I told you exactly why with valid technical reasons.  So why are you showing that useless clip again?
Do you want to improve your performance in your clips?  I suppose that you are not comfortable to speak English in your clips.  Go ahead and speak in your native language of Portuguese.  If you speak clearly YouTube should be able to convert your speech to text and then translate the text into English in real time.  Also do a write-up underneath your clip that states what you are doing as well as summarizing your data.  You can even do that in Portuguese and then we can copy and paste it into Google Translate if we want to.
Kiss my ass with your "have a nice day" BS.  Your whole posting was useless noise and trash talk about me.  Improve your clips so you actually state something of value and you summarize what you did with data.  The last thing we need from you is another clip that says, "Look mom!  I can make an air-core transformer!"
I hope that the moderators of this forum are consistent with what they have done in similar situations with other people that use such language.
Nelson Rocha
PS- Grow big CHILD
Quote from: nelsonrochaa on May 03, 2017, 10:38:15 AM
Nelson Rocha
PS- Grow big CHILD
Hey, you can discuss the project or else you can GET LOST.  I am not here to read useless crap from you about me.
nelsonrochaa
Quote from: MileHigh on May 03, 2017, 10:48:27 AM
Don't be rude man what crap i say about you ? Did you not write what i point ? Just rewind and see what you write .
Are you concerned now if i want improve my performance of my clips : ? I'm not concerned about that .. did you already end your dislikes in my videos ? You could create another account and do again that big child . I don't need improve nothing in my videos because even normal people can figure out the message only you with such intellectual superiority not .
I wish you a nice day again to you
Nelson Rocha
