The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
evostars
yes the Aether is disturbed by the disruptive capacitor discharge impulse from the bifilar pancake coil.
And nature equalises the pressure difference.
at the same time there is a magnetic vortex
and a resonant ringing of the Aether.
the pressure becomes negative from the negative voltage discharge, and creates a vacuum, or low Aether pressure.
like opening a vacuum jar, under water.
the water pressure instantly fills the vacuum of the jar
Belfior
Quote from: evostars on September 07, 2018, 05:57:57 AM
If you put the back-EMF into the cap and the other side of the cap to the ground what happens? Will the ground supply "more positive" electrons to the other side or positive charge appears from "somewhere"
nelsonrochaa
evostars
L3 is also tuned by a capacitor
the whole system is resonant(or interacting on all levels) , so tuning is key
"earth" is still a floating ground. (reference)
did a test with a different setup, and got a disruptive discharge in L2 just before the mosfet turned on in L1 and at the negative maximum of L3(resonant). first I thought it was the inductive spike after turning the mosfet off, but it is before turn on! Why is it happening here, at that specific point in time?
L1 has already lost its magnetic field at this point. what is the trigger, for this event?
also
C3 is parallel over half of L2, using the center tap.
I wonder why. It feels as if it is an energy pump.
will build this the next t days.
AlienGrey
Hi  I don't know if it's relevant or not but I had a go at Nelsons ''radiant exciter'' thinking it would be easy to get going as i'm not sure about the pancake number of speaker wire turns on his new device. However different ferrite torrid's give entirely different frequency's and ringing problems and BEMF
I suspect unless the correct number of turns are known here and any added coatings it could be a real jigsaw puzzle getting the best results.
Happy days eh ;)
