The bifilar pancake coil at its resonant frequency
Started by evostars, March 18, 2017, 04:49:26 PM
ramset
Zephir
Your a new Kid here[and acting more like a Child as time goes by
why do you think there is an OU forum here?
yes your carpet bomb of posts is one reason
but now you call us liars and show no evidence?
You tube videos is your evidence ??
here
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg503680/#msg503680
also to note
a new moderated thread will be started for the Nelson circuit here
Zephir
sad you wouldn't actually work here...
just post things we all have seen a thousand times at the OU forum
Thanks Grandma
tinman
Quote evostars at EF
"That other forum" is clearly not properly moderated. After alot of offtopc shouting and cursing, the moderator himself has joined the offtopic discussion.
As i told you in my reply PM to you--i cannot/will not be some form of dictator,and decide what is and is not allowed on a thread-other than foul language.
This thread is about inductors/coil's,and so,anything relating to any type of inductor/coil,should be able to be discussed without being censored-->and current flow direction through an inductor,when the source current is interrupted, is a vital point to any experimenter.
So,just because things dont go your way,and things are not censored/modderated  to !your! liking,dont go spitting the dummy,and plaster crap all over other forums.
If this forum is so bad,then just leave--it's that simple.
BTW,i watched your below video,and i liked what i saw--i even gave you a thumbs up.
Infact,i am going to wind another bifilar pancake coil,and do some more experimenting.
https://www.youtube.com/watch?v=uhY27Zoor-Q&feature=youtu.be
I wish to see if i raise the frequency high enough,whether or not the current flow will actually reverse,due to self capacitance.
Now im off to watch your other video's.
Brad
Zephir
Quotei am going to wind another bifilar pancake coil,and do some more experimenting.
The winding of bifilar coil will not help you without theory - you should read and know, how to use it.
Otherwise you'll get into position of tribesmen, who believe they will fly if they construct plane from bamboo.
synchro1
@Tinselkoala,
You're showing us your over magnified view of the Moby "Spark Gap Slope" while at the same time offering us a blindfold view of your nothing "Negative Current"; These outrages are coupled with your routine compulsive vitriolic shamelessness! Have you no sense of common decency?
tinman
Quote from: Zephir on April 10, 2017, 08:36:20 AM
Perhaps you should go check out my youtube chanel,and then you will know that this tribesman needs no plane to fly  :D.
Some errors in your video.
1-The magnetic field will never be stable around your coil,until such time as the current flowing through it is continuous and of a stable value.
2- The magnetic field around your coil,will be the same as that found around a donut,or speaker magnet. At the center of your coil,the north field will pass through the center hole,and merge with the south field--it will not take a long trip around the outside of the coil,like you explained in your video.
Below is a pic of how your field will be around your pancake coil.
Brad
