Quote from: synchro1 on April 16, 2017, 08:31:28 PM
@Tinselkoala,
Another "Krell 7th level" Scope Shot? That's the same scope you can't read "Negative Current" off of!  It would help  to understand Australian to translate this: A watt hour is a negative Henry.
Neither you nor Milehigh has ever had a Physics course nor can either of you read or understand the Algebraic expressions we use in the "Henry Formula". This is where you both turn into Hydro-encpheletic Pinheads.
Wrong again, several times over, and again more applicable to Synchro himself as anyone can see from previous posts concerning differential calculus, basic algebra, units, and definitions of electrical terminology.
And of course .... preserved yet more of the nine-year-old petulant child's insults for the record.
"A watt-hour is a negative Henry".... what a laugh.  A WATT-HOUR is a measure of ENERGY, and its units are JOULES. A HENRY is a measure of INDUCTANCE and can be expressed as Joules/Amps2. The two are in no way equal or "equivalent" no matter where you put the minus sign.
Quote from: synchro1 on April 16, 2017, 08:43:38 PM
@Milehigh and Tinselkoala,
I first mentioned "Negative-micro henries to you booth on Gotolucs Than Heinz regenerative gain video, and I insisted you include a "Negative Henry value as a gain of power factor to add onto the COP. Neither of you had a clue and that raised an eyebrow on you frauds back then.
Null content, except for the "frauds" accusation, which is here preserved for the evidential record.
And by the way, Thane Heinz never produced a single Joule of excess energy.
Now, if I can get a word in edgewise between the Ainslie-esque off-topic tramplings of the troll Synchro...
Here is yet another frequency sweep. Previous ones were linear, here is a log sweep from 1 kHz to 5 MHz, clearly showing the "notch" at 273kHz indicating parallel LC performance. This is 2 sweeps of 30 seconds each.
I first mentioned "Negative-micro henries" to you both on Gotolucs Than Heinz regenerative gain video, and I insisted you include a "Negative Henry" value as a gain of power factor to add onto the COP. Neither of you had a clue and that raised an eyebrow on you frauds back then. A higher inductance coil field would factor into an electric power equivalent to deduct from the input. You two sneaked 'Rim Lead" onto the tote wheel in favor of loss.
https://www.youtube.com/watch?v=kQFKtI6gn9Y
I think you need some cheese to soothe your aching psyche.
Great work TK!  The mysteries of the series bifilar pancake coil explored!
