synchro1
Quote from: TinselKoala on April 17, 2017, 08:45:47 AM
Once again your insults and disparagement clearly describe yourself.
And you are having so much trouble typing in your childish rage that you can't even spell "HENRY".   You clearly have no idea what you are talking about. The WATT-HOUR IS A MEASURE OF ENERGY, in JOULES, not inductance which is measured in HENRIES, which can be expressed in Joules/Amps2.  They are in no way "equivalent" no matter where you stick your silly minus sign.
There is current, which is the flow of charge. It always proceeds from a place of higher potential to one of lower potential. Not the other way around. You can stomp your feet and add capital letters but that does not change the facts. The "negative" sign on your ammeters is there to show you which way the current is flowing, not to identify some "negative current".
But as I said earlier, since CURRENT is the flow of CHARGE, and charge in wires is carried by electrons, which have the unit negative charge, some nit picker could say that ALL current in wires is "negative" since it is the flow of negative charge. Nevertheless it still flows from higher potential to lower potential. Only.
Really, Allen Burgess? You say things like that on this forum? Not only do you lie and misrepresent but you are now resorting to PORNOGRAPHY in your insults?
You are truly a sick, sick puppy.
In Texas we know what to do with animals as sick as you are.
https://www.youtube.com/watch?v=L6r7cM3vHRg
You really WANT to get banned, don't you?
You are sick, that is the only explanation for you.
synchro1
@Tinselkoala,
This quote from Energetic Forum refers to Bedini's "Ferris Wheel Motor", The power of "Impulse Magnetization"!
"I'll take a stab at how the boots worked. I think the boot steel is set up like a Leedskalnin perpetual magnet holder (PMH) and it's in the off position. The boot has four of these PMH's on it. The magnet is always attracted to the walking surface when it's in the off position. When a person wishes to take a step all he has to do is pulse the PMH coils once and the magnetic force is redirected into the steel frame of the shoe that holds the steel posts, which removes the force to the floor. Once the pulse has ended the person could place his foot down and the magnet would direct is flow naturally to the steel floor".
synchro1
How much electricity is in a magnet? We can use Dr. Leon Dragone's formulas to help solve this, But The answer is way overunity when the cost of impulse for the the conversion to electric power in the PM as you now understand it.
synchro1
Bedini swaps, collects and redirects the "Impulse Energy".
