3.7 VOLT BATTERY POWERS 56 WATTS
Started by magnetman12003, March 28, 2017, 07:46:43 PM
Vickysong
HKin.com is a business-to-business marketplace dedicated to support companies engaged in the Electronic Components Industry.
We act as a trading hub facilitating companies from all over the world to trade electronic components online. Our Supplier Directory provides comprehensive information enabling buyers to source manufacturers and suppliers in Hong Kong and Asia Pacific area.
www.hkinventory.com
magnetman12003
I have a question to ask:  I can power 9 seven watt 12 volt bulbs and get quite a good output with my setup.  I did notice that when I powered it directly using  a 12 volt 12 amp hour battery my bulbs burn with a intense light much brighter than anything I have experimented before with.
What kind of AC TO 12 volt DC power pack can replace the battery???  I noticed there are regulated and unregulated and with and without transformers.  I  want a unit that will not pulse the bulbs.  I  have 2 units already that do just that rated at 12 volts,6amps.  Someone point me in the right direction
Cherryman
Quote from: magnetman12003 on May 02, 2017, 02:58:19 PM
Maybe you can try aiming them at a solar panel?
Break of the plastic or glass bulbs, make them "spots" and see what kind of power you can harvest from the light and recharge the battery.
And do not forget that you can grow (indoor) veggies (or other) plants easily with those bulbs ( speaking from experience).
Maybe not the direction you asked for, I'm sorry, but keep up the good work!
magnetman12003
I just ran a new 12 volt  power supply through my circuit.  I have 9 twelve volt 7 watt bulbs in parallel.
That's 63 total watts.  I had all bulbs at full brilliance and measured 4.63 volts and 1.21 amps where the power supply was connected to the ""Operating"" setup.    4.63 X 1.21 = 5.6023 Watts powering
63 watts.
magnetman12003
I have an interesting question that someone might answer.  I just bought a 12 volt 30 amp 360 watt power unit.  What 12 volt battery would be its equivalent in amp hours and watts?
