Some Bifilar coil experiments
Started by evostars, April 11, 2017, 04:31:06 PM
Belfior
he is a picture. Under the black tape is the primary. 2 coils of magnet wire with open ends are connected to a GDT
Only "circuit" they share is the soft iron core
http://overunity.com/17119/pulling-energy-from-the-ambient-energy-field-using-a-coil-capacitor/dlattach/attach/165402/
PolaczekCebulaczek
Quote from: Belfior on December 11, 2017, 06:47:24 AM
you still have and inductive loop there. Use 2 magnetic wires. Wind them bifilar.
So the plus goes to the lamp positive leg and minus goes to lamp negative leg. The arrow end you leave open, so there is no closed circuit. In your image the coil is closed.
Ontop of this you wind a regular primary and pulse it. The lamp lights up, even there is no closed loop.
My own setup was to have a primary over an iron bar. Then I had 2 open ended coils over the same bar and they have a lamp between them. Again the coils that are open ended and the lamp lights up. This is something I was told a cannot exist
In your case some people are saying that you had SOME SORT OF capacitor where open coils are plates? (I fail to see how electric field charges such plates) however in my case, this is not a capacitor, its a loop, electrons cant flow against each other, are they? when LED blinks we have indication of some small current also LED works in any direction so its AC? In your case, if you short your open coils the LED still light's up?
Belfior
I think with open ended bifilar you might be charging the dielectric and not the plates. I know something flows in the open ended coils, because the light is there
I am moving and all my builds are in boxes. Didn't get through all my tests so I did not short the coils. I can continue in January :(
PolaczekCebulaczek
If you connect two coils in the same way as I did for non inductive primary bifilar (forming one coil) you will get the same effect as I do. Current against current.
tysb3
I think there is a static electricity
