Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
Zephir
Test circuit scheme from the LTSpice IV file provided by @Theoretical_Research above. 30M Self-adhesive Conductive Copper Slug Tape, which can be used for coil shielding (it's nonconductive at the tape side, so that no short winding should be formed). According to FEMM simulation the placing of low dielectric material (such as balsa wood) between the copper foil and core should significantly decrease charge cancellation, depending on balsa wood thickness.  @Theoretical_Research provided additional useful tips for replication in the another forum here. Initial testing of the TV yoke core using the same procedure by @partman produced null results though.
Thanks. I don't think partzman has built the EGS effect circuit yet. He did some initial tests on a flyback core using a circuit according to how he thought I might be doing the experiment and got a change in voltage when rotating the core, although I don't know how much. I suspect it was a small change, but I haven't analyzed his scope shots. Partzman I think repeated that same setup of his using a flyback core and got no results. In his first test using the flyback core he noticed the effect was observable at certain harmonics. I believe that's because the phase angle between the EGS voltage and signal generator leakage at those specific harmonics were in phase enough to see the EGS voltage. When he takes the core measurements, enters them into the ltspice sim, adjusts the ltspice params as describe in the instructions, then he should definitely see the EGS effect. Although it appears he's already seen the EGS effect.
"Interestingly, there are differences in amplitudes of certain harmonics.  The R3(wht) trace is the stored FFT when the core is in one position, and the Math(red) trace is with the core flipped 180 degrees." partzman
http://www.overunityresearch.com/index.php?topic=3447.msg60838#msg60838
Zephir
@Theoretical_Research: I'm afraid, that the overunity effect which requires careful simulation in Spice and subtracting the results for to manifest itself has no chance for practical success anyway. What we need for occasional overunity is the arrangement, which would generate output voltage in robust way without need of any simulations, i.e. out of explanation by stray capacitive currents with classical physics. From this reason I would NOT place the output coil over the capacitor foil - but at free space at safe distance from it, preferably to  another arm of torus free of capacitor foil.
If it will kill the output signal from the coil, then it would also mean, that the capacitor foil isn't actually required in other places of ferrite, than just under the coil - which is strange with respect to your theory and it would also indicate the capacitive artifact instead of real phenomena. If the output signal will still persist, it will be great - but it would also mean, that no LTSpice simulations are actually necessary and that we can reproduce the effect by introduction the voltage gradient at random place anywhere along ferrite - which would enable us to isolate the output coil from polarizing input voltage completely. In addition I would cover the coil with grounding tape for to avoid any stray voltage leaking into it from outside.
Hi Zephir. I guess we see it differently? Posting at two forums takes too much time. I'll be at the other forum if anyone wants to contact me.
vasik041
Quote from: Theoretical Research on April 22, 2017, 12:07:17 PM
sadly, not everyone can register there  :(
