Witness the Free Energy effect
Started by Theoretical Research, April 16, 2017, 05:16:47 PM
PolaczekCebulaczek
Thank you! I think i understand now, capacitor is powered by AC so E field in between plates is alternating so E field/dielectric current makes B field that interacts with B field in magnetized (by coil) core and core "vibrates" and inducing back spike current in coil.
The force is in the same direction regardless if the current is + or -. So when the AC current reverse polarity during the other half of the cycle the dielectric current is reversed and the B-field is also reversed. So a negative times a negative is still a positive. That's why the force can be in the same direction. Of course it doesn't have to be that way.
If a permanent magnet is used instead of the magnetic core then it will only vibrate.
partzman
TR,
I still have the rotary test jig available for any replication attempts.
Pm
Quote from: partzman on October 30, 2017, 10:01:58 AM
TR,
Pm
Thanks. That will come in handy. Hopefully this week I'll have a safe air core design ready for anyone who wants to build it, if all goes well. It would be very helpful to know the general location and output voltage of each device, along with the direction and intensity of the Earth's magnetic field. There are free phone apps that will tell you the x,y,z magnetic field. Some locations have anomalies such as a vertical magnetic field.
If anyone is located south of the equator or near one of the planets poles or near the equator then I would >>>>>>>>>>>greatly<<<<<<<<<<< appreciate your results. Every replication will help. This will help map out the planet's space flow velocity to get a better idea what's happening.
