Replication of Mini Radiant Exciter circuit of Nelson Rocha
Started by Zephir, April 21, 2017, 11:26:19 PM
nelsonrochaa
Hi everbody ,
I could see by last updates , most are trying lit up neon bulb :)  Is there any special reason for this to happen?
I have already said, and I repeat:
The purpose of this circuit is not to ignite neon bulb lol, even because in the original circuit there is no neon connected at the transformer output, but near the input of the circuit near the capacitor C5 maybe people should consider search by negative resistance theme and will find better explanation to i use the neon bulb.
I already describe that hv radiant output when circuit is property tuned is capable to charge a capacitor just by one wire without apparently increase the input , or even be used to transmit electric power by one wire . In the video we could see just one wire connected to one coil and be received by other isolated coil .
https://goo.gl/photos/mXtpKMi9L69WVjVBA
We can see too how different are the wave shot in scope from most of replications until now, and without burned transistors :)
The circuit could do that operation and in same time recharge a battery without impact in input . I just saw one person show that until now
call's MAC and he made one video https://www.youtube.com/watch?v=iER4K1O7iMc&t=17s
Like i said since first beginning this circuit is just to be study , And is part of a learning process to other nice project, but..... i know "is only a JT" like most pro people say , and in that way i just could answer to "Pro's" replicators  :
don't need spend  their precious time in something that is so simple and trivial  , just ignore  ;) and go forward in other projects.
I just say that  because already saw some "elite" replicators at end of some days of experiment with this circuit, start complain why are spend their time with something is only a simple JT and they have better alternatives circuits to lit several neon bulbs .
To the people real interested i know they will have moments of fun and learning with that circuit not any doubt .
Nelson Rocha
Jimboot
Quote from: nelsonrochaa on April 23, 2017, 06:50:03 AM
Hi everbody ,
Nelson Rocha
Thanks Nelson, most of the fun I am having with this circuit is when the neon is not lit :) Seeing very curious things.
nelsonrochaa
Quote from: Jimboot on April 23, 2017, 08:25:04 AM
Hi Jimboot,
My intent since begin when i authorize Grumage to open the thread with my circuit , was exactly stimulate new people to observe what i consider interesting points related with  MAIN subject of this forum  OU , but i understand to some persons could be trivial what they observed , but not to everyone, and i think this forum is not only made by a "Elitist group" but by lot new people that could have the interest of reproduce that circuit and learn with lower investment about nice points .
I not earn nothing with that , even because i know in detail all points of that circuit and other variations that i did in last years .
I'm not selling any PDF or any promise of OU . Is really free of charge to the interested people .
Thanks by your support and wish you luck
Nelson Rocha
Nelson Rocha
Zephir
We have at least three replications already, but they all behave in unpredictable way and they oscillate more wildly, than the Mini Radiant Exciter at original videos.. For now they all also ignored my recommendation to replicate Nelson Rocha's prototype exactly. If nothing else, then the ferrite rod passing the toroid will block high frequencies propagating into circuit and it will make it more harmonic and less unpredictable.
In addition, Mr. Rocha pointed to interesting behavior, like the recharging of capacitors and another effects, which are visible at his videos. Instead of playing with neon lamp these effects can be tested for now.
padova
Hi
I've tried MAC's schematic or more precisely part where C5 is in parallel whit C2, initially results were poor,
so i dropped that, although it's  in MAC's  schematic.
I was trying to rejuvenate an old led battery whit this circuit. In absence of new informations,
but now we have some hints from Nelson about that part of the circuit. So will see to it.
regards
